Author Topic: 1969 to 1971 (?) Aquasport 19-1 Osprey Rebuild Soon  (Read 12939 times)
October 18, 2009, 09:10:33 AM
Reply #75
GarrettS
Re: 1969 to 1971 (?) Aquasport 19-1 Osprey Rebuild Soon
« Reply #75 on: October 18, 2009, 09:10:33 AM »
I was able to assess the transom yesterday and I think I can work with it. It isn't going to be a typical AS rebuild now. Instead it will have a slightly rounded transom (which might look good?) except for where the bracket mounts. Here is what I did to determine if I needed to cut the whole thing out.
I built a frame around the edge of the transom 1.5" away from the surface (well within the bulge height). I used this frame to scribe the curve that would compensate for the bulge.
Cut out that curve (made it smoother with a bent piece of strapping) and transferred it to 1/2 plywood.
The 1/2 would become a template for the cap.
I left it long because I didn't know how much height I would need in the cap to make it look correct. After bracing it in the center I was able to mark where it needed to be cut.
After deciding the best shape for the curve height I trimmed the excess off.
Remember, this is only a template, not the finished cap piece.
Today I hope to get the knees glassed in and move the bulkhead around for the bilge area. I don't think having a compound curve for the transom is going to be that bad looking. It definitely isn't going to be 100% original. I am just not willing to spend another $500 and two or three weeks fixing this when I think the final result won't be that noticeable. We will see what it looks like when the paint goes on.
Garrett
1969 Aquasport Osprey 19-1
115 hp V4 Yamaha Saltwater
October 18, 2009, 11:04:17 AM
Reply #76
Marcq
« Reply #76 on: October 18, 2009, 11:04:17 AM »
Quote from: "GarrettS"
BTW do you have snow in Montreal yet?
Pleaseeee don't mention snow  :puker:  :puker: . No white sh*t yet, still hoping will get an Indian summer
Hey, it's looking good, what did you do on the interior of the transom? Looks super flat now  :thumleft: and good idea about rounded transom
Marc..
October 18, 2009, 04:45:14 PM
Reply #77
GarrettS
« Reply #77 on: October 18, 2009, 04:45:14 PM »
Marc,
Sorry about the S comment. I didn't do anything to the interior. It is very smooth, just with a bulge.  I think I will definitely need longer mounting bolts. I got the knees ready to glass but it is way too cold and rainy. I will try to get them in next w/e.
Garrett
January 28, 2010, 03:33:09 PM
Reply #78
Skoot
« Reply #78 on: January 28, 2010, 03:33:09 PM »
Garrett, are you still alive? :geek:   Hows progress? Any pics?
1975 19-6 - 90hp Tohatsu
January 28, 2010, 07:56:39 PM
Reply #79
GarrettS
« Reply #79 on: January 28, 2010, 07:56:39 PM »
I am still alive just dealing with WINTER in the northeast. I resolved the issue with the transom bulge by creating a jig and using a skill saw to cut out the high points. I used a chisel too. Here is a brief synopsis.
And then I made a template to be fiberglassed.
It got too cold to work outside with fiberglass so I am in limbo until the spring. The template is just 1/2" CDX the actual will be made of 1/2" marine. Here is another view.
I decided that I wasn't willing to rip everything out and spend another $500 plus just to get the transom perfectly flat. There will be a slight curve to the transom.
This is the ground version
Garrett
