Author Topic: 1989 Aqua Osprey 20 - Tank size? Fuel burn?  (Read 861 times)
July 11, 2009, 09:06:34 AM
Read 861 times
gotime242
« on: July 11, 2009, 09:06:34 AM »
Hello all!
I am the new owner of a 1989 20', and i love it so far. Im sure i will have a ton of questions in the future, but i will just start out with....what is the fuel tank size on this boat?
Also, i have an original 89 evinrude 150 on it, what could i estimate the fuel burn to be? Thanks!!
If i were ever to re-power it, would a 200hp be an option? Or is that too much for this boat?
Thanks!!
July 11, 2009, 11:21:53 AM
aquasport79
Re: 1989 Aqua Osprey 20 - Tank size? Fuel burn?
« Reply #1 on: July 11, 2009, 11:21:53 AM »
I believe 50 gal tank size, 2-3 MPG and a 175 is the biggest I would put on there. Your boat is pretty light. Another new 150 would work just fine as well.
July 11, 2009, 12:33:38 PM
scott_gunn
« Reply #2 on: July 11, 2009, 12:33:38 PM »
I can confirm and agree with everything aquasport79 said. I have a 1987 20' Osprey.
July 11, 2009, 01:32:24 PM
gotime242
« Reply #3 on: July 11, 2009, 01:32:24 PM »
Thanks for the help guys!
Well....after doing some research on fuel tanks, just out of curiosisty, i decided to pull some of the access ports off and have a look at whatever i could find. I found that i have a 36 gallon "Tempo" fuel tank:
http://www.tempoproducts.com/2004/bd_fuel_tanks2.html
It seems to be plastic/polymer...so that MIGHT be a good thing. At least this means it was probably repalced at some point?
What do you guys think, is this a good tank?
Thanks!
