Author Topic: TACH TROUBLES  (Read 882 times)
June 23, 2009, 02:04:52 PM
Read 882 times
greazy
TACH TROUBLES
« on: June 23, 2009, 02:04:52 PM »
1973 19-6 1983 Evinrude 140 tach was not wired total mess of wires when I bought the boat. I cut out all of the BS that was for old ecectronics and tried to get the tach to work. according to the schematics I found thanks :lol:  to a site member it said the grey wire from the harness should be for the tach. NO WORKIE.. I traced the wire back under the cowl and found that it is connected..?? Is this the right wire does anyone know?? I connected the ground to the battery that cranks the engine and positive for the lamp inside the tach and the grey wire to the input. any help would be appreciated. I thought this would be like a tach on a car..maybe not. thanks GREAZY
June 23, 2009, 03:52:39 PM
Re: TACH TROUBLES
« Reply #1 on: June 23, 2009, 03:52:39 PM »
I don't know myself , but when in doubt search the web! I hope this helps since I've got to do all of mine!
http://forums.iboats.com/showthread.php?t=186986
 Good luck! :afro:
June 23, 2009, 03:59:38 PM
Re: TACH TROUBLES
« Reply #2 on: June 23, 2009, 03:59:38 PM »
Hey greazy please make sure and post back as to what worked because if it works on yours it will proably work on my 86 150. Thanks!
July 12, 2009, 10:11:54 PM
Josh38
  • Guest
Re: TACH TROUBLES
« Reply #3 on: July 12, 2009, 10:11:54 PM »
Ok it is the grey wire. The purple is a keyed hot wire. use the the purple to power the tack the grey from the engine and the most important is to make sure your ground is well connected. This should have your tack wired correctly. If that does not work have the tack checked.
July 13, 2009, 05:07:56 AM
Re: TACH TROUBLES
« Reply #4 on: July 13, 2009, 05:07:56 AM »
Welcome aboard Josh38  :!:  :!:
July 14, 2009, 09:57:06 AM
Re: TACH TROUBLES
« Reply #5 on: July 14, 2009, 09:57:06 AM »
Is the charging system working?  JohnnyRudes are known for the tach not working being caused by the voltage regulator.  The regulator also sends out the tach pulses.
July 27, 2009, 11:14:22 PM
bdtsr
Re: TACH TROUBLES
« Reply #6 on: July 27, 2009, 11:14:22 PM »
Tach signal comes from the stator. It is passed through the rectifier/regulator on 9 amp and higher systems and out the gray wire. On 6 amp system the yellow/gray wire from the stator ties to the gray tach wire in the engine harness. Manual tilt models used a 6 amp rectifier ($60, 3 wires, red, yellow and yellow) and power tilt models used a 9 amp rectifier/regulator ($375, 5 wires, yellow, yellow, gray, black, and red). Just did a rectifier on a 1986 115hp OMC. Arcing the battery cables can/will take out most OMC rectifier/regulators.
1978 Aquasport 200 CCP 1990 225hp Yamaha
1990 Bayliner 2302 Trophy 2000 225hp Optimax
1999 Bayliner 1950 Capri Bowrider Merc 3.0 liter I/O
1986 Arrowglass CC w/1986 Evinrude 115hp
3 Kawasaki Tandem Sport Jet skis
1993 Seadoo XP
1988 Yamaha WR500
