Author Topic: 115hp enough for a 1977 19-6?  (Read 795 times)
June 20, 2009, 06:52:03 PM
Read 795 times
fox
« on: June 20, 2009, 06:52:03 PM »
I have a pretty soft '77 19-6 with a 1995 150hp v6 Suzuki EFI that need a new short block for about $5k.  Alternative is a local dealer I trust who has a 2000 Tohastu 115hp - well maintained, all records, etc... and ready to go for about $3,500 installed.
1) wondering how the 115hp will drive this gal.  The 150 is a bit heavy, but damn she flies on a calm day...  flip side is that the 115hp is about 100lbs lighter and would give me a little more sea room in the transom.
2) if you had to choose - what option?  (and no, buying new is not a possibility right now)
3) drastic option is to buy the Mako 211 down the street.
4) Dream option is to re-build the boator find a more solid 19-6...but also out of reach.
thanks!
June 20, 2009, 07:21:25 PM
MarshMarlowe196
Re: 115hp enough for a 1977 19-6?
« Reply #1 on: June 20, 2009, 07:21:25 PM »
115 will be fine.  35-40mph .  I've heard some so-so things about older 2stroke Suzuki's, but I've never heard anything bad about a tohatsu.  My neighbor is a commercial shrimper and drags a net all day with a tohatsu.
If the boat's soft as you say, you'd be better off with a lighter outboard.
Key West 1720 / Yam C90
Sold: 1973 Aquasport 19-6
June 20, 2009, 11:30:52 PM
thill
« Reply #2 on: June 20, 2009, 11:30:52 PM »
That 115 should run it nicely.
What do you mean by "soft"?
-TH
June 21, 2009, 07:44:59 AM
fox
« Reply #3 on: June 21, 2009, 07:44:59 AM »
"soft" meaning decks are a bit squishy, and the transom, while solid, is not exactly a rock.
June 21, 2009, 03:58:02 PM
« Reply #4 on: June 21, 2009, 03:58:02 PM »
Maybe you didn't see this pic I posted, this is from 1978 or 79. Yes those are 70 Johnsons.
June 21, 2009, 04:35:20 PM
fishcole08
« Reply #5 on: June 21, 2009, 04:35:20 PM »
Just purchased a '73 19'6 w/ Yamaha F115...
Was worried about the weight but it is ok... The 115 is plenty of power...
June 21, 2009, 07:19:20 PM
« Reply #6 on: June 21, 2009, 07:19:20 PM »
the 115 is ok if you dont carry a heavy load, my '96 with a 112 johnnyrude runs average 37-38 mph, and i've seen almost 43 mph (42.8 to be exact)
