Author Topic: Watertite simple question  (Read 734 times)
June 16, 2009, 02:20:20 PM
Read 734 times
lackofcommitment
« on: June 16, 2009, 02:20:20 PM »
Hi Guys,
I have a 170 that i need to do a couple quick patches on the hull. Will Watertite epoxy filler bond well to the original polyester? I get a little confused about the back and forth.
Thanks,
Alex
June 16, 2009, 08:28:13 PM
Re: Watertite simple question
« Reply #1 on: June 16, 2009, 08:28:13 PM »
Haven't used it myself but most any epoxy is usually far superior over polyester rather than polyester itself.
June 17, 2009, 08:44:44 AM
« Reply #2 on: June 17, 2009, 08:44:44 AM »
Epoxy will always bond well to polyester, polyester will almost never bond well to epoxy.  Note I said "almost".
Watertite rocks, I recommend it.
June 17, 2009, 08:45:13 PM
lackofcommitment
« Reply #3 on: June 17, 2009, 08:45:13 PM »
Thanks! I get confused because in the surfboard world epoxy and polyester dont mix. But now I know.
June 23, 2009, 10:28:15 AM
Skoot
« Reply #4 on: June 23, 2009, 10:28:15 AM »
Quote from: "lackofcommitment"
Its because of the foam blank, not the polyester resin itself.  Surfboard foam blanks are made from either EPS or polyurethane foam. This in turn determines the sort of resin that will be used in making the surfboard. Epoxy surfboards have EPS cores. Polyurethane blanks are compatible with polyester resins and traditional fiberglass surfboards.
1975 19-6 - 90hp Tohatsu
