Electrical
Rewiring my boat
Topic: Rewiring my boat (Read 1253 times)
June 06, 2009, 12:32:52 AM
Read 1253 times
JoseGaspar
Rewiring my boat
June 06, 2009, 12:32:52 AM »
Apologies if this topic might be a re-post (links to originals would be great). I'm planning on getting rid of the rat's nest of wiring on my 25CCP and rewiring the whole boat. I want to do it myself vs. paying someone to do it because I'm a "pride of ownership" type guy and a self-proclaim DIY. I have some basic understanding of marine electronics, but I'm hoping some folks in this great community could steer me towards some good books/manuals to help me in my endeavor.
Anyone with some suggestions on boat wiring books/manuals to help me with my project?
Thanx in advance.
JG
June 06, 2009, 08:07:23 AM
Global Moderator
Re: Rewiring my boat
June 06, 2009, 08:07:23 AM »
JG
Here's a place to start on theory and basics
http://easyacdc.com/
This will give you an idea of how you probably will end up running your wiring
http://forums.iboats.com/showthread.php?t=186986
You probably have a dedicated switch for different accessories such as bilge pump, nav. lights, anchor light, cockpit and compass lighting and probably more on your size boat. You'll want to wire each of those separate from one another (logical) with the power feed but you can still daisy chain the grounds.
Here's a book that may be helpful
http://www.sheridanhouse.com/excerpts/underboatwiringexcerpt.html
And from the boat wire people
http://www.cncphotoalbum.com/doityourself/wiring/wiring.htm
Boat wiring is fairly basic stuff, the key is to use the proper size wire and connections. Over time, the environment will damage unprotected splices and terminal ends.
Good luck and take some pics as you go.
June 06, 2009, 10:33:03 AM
Mechanical Master
June 06, 2009, 10:33:03 AM »
As with any job, the key is in the planning. Think about where you want the batteries (under the console?), and where key loads might be (motor in the back, windlass at the bow?), then plan wire sizes, disconnects and protection (switches, fuses, breakers), and last comes wiring to individual components. Color coding is always a great idea, so you know what a wire does when you see it in the future. You can also label wiring at key locations and do the same thing.
There are several threads on this forum with details and pics of others doing what you want to do. Search around a bit and you can come up with a good plan!
June 06, 2009, 11:05:02 PM
JoseGaspar
June 06, 2009, 11:05:02 PM »
Guys, thanks for the replies and the great information. I'm planning on keeping the dual battery set-up under the center console and duplicating the same basic set-up but with upgraded switches, marine-grade wiring, butt splicing and heat shrink on all connections.
Many Thanks,
JG
June 11, 2009, 10:44:10 PM
June 11, 2009, 10:44:10 PM »
Jose - where are you located? I may be able to save you some money on parts... I have some hookups - let me know.
June 12, 2009, 07:33:01 AM
JoseGaspar
June 12, 2009, 07:33:01 AM »
I'm in Dunedin, Florida.
June 15, 2009, 08:39:51 PM
June 15, 2009, 08:39:51 PM »
Lemmeknow what you need. Shoot me a PM if interested.
June 17, 2009, 09:42:32 AM
JoseGaspar
June 17, 2009, 09:42:32 AM »
LilRichard, thank you. I'm currently in Europe and Asia on business, but will be back at the end of the month and can connect with you then.
Thanks,
JG
July 15, 2009, 11:23:30 AM
billfish33
July 15, 2009, 11:23:30 AM »
http://shop.genuinedealz.com/Marine%20E ... %20Supply/
When I rewired my boat, I got most of my wire and terminals from them.
1977 22-2 Family Fisherman,200 HP Merc,2.5L
This boat was stolen by our 3rd partner john {who claimed sole ownership with this boat being in his wifes name}
1993 Grady White Gulfstream with a brand new Suzuki DF 300 {30"}
Electrical
Rewiring my boat
