Author Topic: Starter doesn't catch always- 115 Rude  (Read 1123 times)
May 26, 2009, 02:36:25 PM
Read 1123 times
Fishhyren11
« on: May 26, 2009, 02:36:25 PM »
I've had issues with the starter on my 84' 115 Rude lately.
The starter sometimes doesn't "pop-up" and catch the flywheel gear.
But you can hear it free spinning.
2nd, When it does catch, it seems to really struggle to turn over for the first few revolutions then it gets going.
Is this a starter issue, or is this a battery issue?  I recently purchased a new battery (~880CCA).  Was this too small for this engine?
If it's the starter, would a new brush kit help this?
Thanks!
May 26, 2009, 04:41:25 PM
Re: Starter doesn't catch always- 115 Rude
« Reply #1 on: May 26, 2009, 04:41:25 PM »
Sounds like a battery - needs enough juice to pop up high enough to engage the gears otherwise it does like you said - just spins.
May 26, 2009, 05:00:36 PM
Marcq
« Reply #2 on: May 26, 2009, 05:00:36 PM »
I would say bad wire connections , clean them out and try again and of course make sure the battery is fully charged
Marc..
May 26, 2009, 05:05:45 PM
Fishhyren11
« Reply #3 on: May 26, 2009, 05:05:45 PM »
10-4, I'll double check all the connections-
It's quiet possibly a dirty connection-
I remember checking the voltage at my bow light when I had some issues and it was like 9.5V and the battery was at ~13V
I'll take apart the battery switch and sand the connections as well as the wire block by the engine.
I'll report back next week hopefully with good news!
Thanks again.
May 26, 2009, 05:50:06 PM
« Reply #4 on: May 26, 2009, 05:50:06 PM »
im only running a 750 cca battery (if that) with my 112 johnny and it spins the starter no problem... my guess is '84 thats probably never been replaced, connections may be a little green somewhere...
May 26, 2009, 06:51:40 PM
MarshMarlowe196
« Reply #5 on: May 26, 2009, 06:51:40 PM »
Bad starter.  Had the same problem on my old Jonny.  I went through changing the springloaded gear assembly, and it still didn't work.  Not worth the time and frustration.
Buy a new one - less than $100.00, and easy to install yourself, and worth the peace of mind.
Key West 1720 / Yam C90
Sold: 1973 Aquasport 19-6
May 26, 2009, 08:58:36 PM
Marcq
« Reply #6 on: May 26, 2009, 08:58:36 PM »
Quote from: "Badonquasport196"
Yeah but, that wont do him any good if the connection are bad. Actually a good way of testing it, is to provide power directly at the starter,too easy
Marc..
July 27, 2009, 11:35:13 PM
bdtsr
« Reply #7 on: July 27, 2009, 11:35:13 PM »
This is a classic case of low voltage to the starter.
Clean ALL battery cable connections (as stated)
Load test battery(s) and replace if needed
Replace starter
1978 Aquasport 200 CCP 1990 225hp Yamaha
1990 Bayliner 2302 Trophy 2000 225hp Optimax
1999 Bayliner 1950 Capri Bowrider Merc 3.0 liter I/O
1986 Arrowglass CC w/1986 Evinrude 115hp
3 Kawasaki Tandem Sport Jet skis
1993 Seadoo XP
1988 Yamaha WR500
July 28, 2009, 04:19:50 PM
Fishhyren11
« Reply #8 on: July 28, 2009, 04:19:50 PM »
After cleaning all the contacts to the battery, replacing one cable, and cleaning the post in the back, everything appears to be working great now!
I also cleaned the starter. Little and shot the spring/post with some WD40!
Thanks for the suggestions!
July 28, 2009, 08:47:57 PM
« Reply #9 on: July 28, 2009, 08:47:57 PM »
:salut:
