Aquasport Discussion
1981 200 XF question
Topic: 1981 200 XF question (Read 1451 times)
April 29, 2009, 04:35:33 PM
Read 1451 times
April 29, 2009, 04:35:33 PM »
Hello,
I'm considering a 1981 200 XF to purchase. The boat has no power right now but seams to be in solid condition for a 28 year old boat. The floors are rock solid, there are no cracks in the gel coat, and the transom seems solid. Is there any common problem areas that I should look for?
Thank you,
Bruce Smith
April 29, 2009, 04:40:05 PM
Re: 1981 200 XF question
April 29, 2009, 04:40:05 PM »
Oh here are some pics of it:
April 29, 2009, 04:53:23 PM
jdupree
April 29, 2009, 04:53:23 PM »
Bruce,
You just mentioned the 3 main problem areas when buying a boat. If all those are good as you say, chances are the boat is solid.
One thing I would count on is a new tank. If that is the original tank if it is not bad now it will be soon. My only other suggestion would to be to check out the wiring situation as far as what works and what doesn't. Looks like a solid boat :!:
John L. Dupree, III
AQABLA84E999
Member #257
April 29, 2009, 06:06:12 PM
April 29, 2009, 06:06:12 PM »
Yup I've been down the "tank" road before. That is why I like the Aquasport "tank hatch" in the floor. No cutting up a deck to get out the tank.
May 01, 2009, 10:25:49 PM
May 01, 2009, 10:25:49 PM »
Well, I'm the proud new owner of a 1981 200 XF walkaround! I can't wait to get to work on her!
May 01, 2009, 11:32:48 PM
May 01, 2009, 11:32:48 PM »
Congrats! What ya gonna do for power?
May 01, 2009, 11:59:03 PM
May 01, 2009, 11:59:03 PM »
Quote from: "slvrlng"
Well, I'm kinda on the fence about that. I have a good running 125 Force with a fresh power head that is currently on a 20' Renken cuddy. I'm planning on pulling the 125 off and hauling the Renken to the dump tomorrow. I can't decide if I should give the 125 a try or sell it and get a 175 or 200. I know the 125 won't set any records but at least I know it's history. I can' afford a new motor so anything I buy will be used and unknown unless I overhaul it first. Any thoughts?
