Author Topic: Transom Mount live wells for 170s  (Read 1575 times)
April 14, 2009, 12:42:57 PM
Read 1575 times
Fishhyren11
« on: April 14, 2009, 12:42:57 PM »
I've seen these in a few pics of 170s...
Where do you find them?
How do they affect ride?
April 14, 2009, 04:02:19 PM
luv2flycessna
    • http://s364.photobucket.com/albums/oo90/luv2flycessna/
Re: Transom Mount live wells for 170s
« Reply #1 on: April 14, 2009, 04:02:19 PM »
Quote from: "Fishhyren11"
The ones I had on mine I removed and Badonquasport196 is taking
very hard to find.
When I removed mine it seemed like they acted like trim tabs a bit, I did notice it was little harder to get out of the hole and longer to get on plane. I have since added a hydrofoil and has gotten it back to what it was like with the live wells on it.
Hope this helps you some.
luv2driveaquasport
\'74 19-6 \'86 Mercury BlackMax 150HP
May 20, 2009, 10:46:42 PM
MarshMarlowe196
« Reply #2 on: May 20, 2009, 10:46:42 PM »
I wonder if the optional stern mounted livewells were the same size and shape for the 170 & 19-6?
There doesn't seem to be much information on them...
Key West 1720 / Yam C90
Sold: 1973 Aquasport 19-6
May 21, 2009, 11:06:12 AM
Fishhyren11
« Reply #3 on: May 21, 2009, 11:06:12 AM »
Quote from: "Badonquasport196"
Yeah, it would be nice to find SOME sort of livewell in the back of the boat!
Buckets aren't a very clean solution!   I guess a cooler w/spraybar might be the next best thing.
May 21, 2009, 02:26:19 PM
MarshMarlowe196
« Reply #4 on: May 21, 2009, 02:26:19 PM »
Fishy-
I believe there was an option in the 70's to add either the stern-mount style livewells, or to place boxes in the stern inside the cockpit.  But... that doesn't really help you much now...
The great thing about the boxes- if you set them up correctly, you shouldn't have to use an aerator pump at all.  They're very simple and work great.
I could trace the mounting side of my boxes and mail the sketch to you if you'd like
OR
you could probably trace the stern yourself and make them.  They're very simple after all...  I believe at least one member (REELCLIMAX) has made some of his own-
viewtopic.php?f=6&t=3726&hilit=+stern
Good Luck!  :salut:
