Engines & engine woes
Funny Tach
Topic: Funny Tach (Read 1040 times)
April 10, 2009, 10:01:23 AM
Read 1040 times
Double Trouble
NorthEast
Funny Tach
April 10, 2009, 10:01:23 AM »
Another new adventure what could cause a tach to be eratic my starboard engine runs fine what could cause the tach to jump around it will go from1000 to 2500 and back to 1500 then stay steady for awhile and start all over again.Could it be as simple as a bad tach or wiring. Thanks for any help.
2000 275 Explorer Twin 200 Rudes
http://picasaweb.google.com/johne230/My ... directlink
April 10, 2009, 06:04:31 PM
Mechanical Master
Re: Funny Tach
April 10, 2009, 06:04:31 PM »
Sounds like a loose wire - that's the easy fix.
I could not tell the year and model of your motor, but it also could be a stator getting ready to go out, as some tachs read stator pulses - that would be the not-so-easy fix. :(
Let's hope for a loose wire; fix it and you're done!
See ya on the water!
April 10, 2009, 06:55:05 PM
Re: Funny Tach
April 10, 2009, 06:55:05 PM »
My Johnson Oceanrunner tach went nuts. It quit charging at the same time. The voltage regulator was bad.
April 11, 2009, 03:53:00 AM
Double Trouble
NorthEast
Re: Funny Tach
April 11, 2009, 03:53:00 AM »
My engine is charging just fine so I will look into the loose wire theory thanks for your help.
April 13, 2009, 10:16:15 AM
Fishhyren11
Re: Funny Tach
April 13, 2009, 10:16:15 AM »
I'm going to have to agree, this sounds like a voltage regulator that's going out....
Mine went out, and my tach is going nuts, I got a new one, but still don't know how I'm going to put this thing in.
April 13, 2009, 01:05:49 PM
Double Trouble
NorthEast
Re: Funny Tach
April 13, 2009, 01:05:49 PM »
Took the tach out today cleaned all the contacts with electronic spray turned the adjustment knob a couple of times and sprayed that put it back together and wala works fine,sprayed and cleaned the other tach as well as the rest of the gauges while I had the dash apart.If any body fools with that adjustment knob take note of original setting first.
Funny Tach
