Author Topic: Porta bracket on 19.6  (Read 3843 times)
April 07, 2009, 08:16:07 AM
Read 3843 times
tunahelper
« on: April 07, 2009, 08:16:07 AM »
Has anyone put a Porta bracket on a 19.6 with a OMC V4.  a buddy of mine was thinking about doing this.  My thoughts were it would throw off the balance too much.  Has anyone gone down this road before and what were the results?  Was it worth it?
April 09, 2009, 08:05:13 AM
klthomas
Re: Porta bracket on 19.6
« Reply #1 on: April 09, 2009, 08:05:13 AM »
I am planning on putting one on mine, but it will be a few months before it is ready.  I am also very intersted in knowing if any other 19.6's have used the porta bracket.
April 09, 2009, 09:35:00 AM
« Reply #2 on: April 09, 2009, 09:35:00 AM »
I talked to Tommy at Hammerhaead and he said he has done them. Call him to get his opinion.
April 09, 2009, 10:21:08 AM
« Reply #3 on: April 09, 2009, 10:21:08 AM »
Welcome aboard tunahelper  :!:  :!:
Where are all these 196s coming from all of a sudden  :scratch:
April 09, 2009, 02:16:34 PM
MarshMarlowe196
« Reply #4 on: April 09, 2009, 02:16:34 PM »
Quote from: "RickK"
We all got together and decided that we were tired of boating in the shadow of CCP's and 22-2's...  :)
Key West 1720 / Yam C90
Sold: 1973 Aquasport 19-6
April 09, 2009, 08:34:24 PM
scott_gunn
« Reply #5 on: April 09, 2009, 08:34:24 PM »
I am curious if anyone can give a personal experience as well. However, I have thought long and hard about it for my own 196, and I think I would go with just a regular Bob's jackplate with a 6" setback or something like that.
Sure, you wouldn't be able to completely close in the transom without leaving some kind of notch in it (or just be careful to always raise the engine before tilting up).
But then you don't run the risk of messing up the handling and ride. These boats ride much better with the nose down in most conditions. You don't really give up anything else. You'd still be able to raise the motor and idle through really shallow water, and I doubt you'd draw anything noticeably more while on plane either.
If you do go with a portabracket, you might want to consider moving the gas tank forward, putting the batteries in a forward compartment somewhere, and definitely getting trim tabs.
April 09, 2009, 09:38:18 PM
tunahelper
« Reply #6 on: April 09, 2009, 09:38:18 PM »
Scott, I'm from Palm Harbor also.  The reason I ask, is that I have another buddy who has a 222, and he did the full transom with a Porta bracket.  His boat needs full down trim to keep from porpoising.  I don't think he changed the tank or battery location.
The other friend I have came across a deal on a Porta bracket and is not real internet savvy.  I  told him I would check the Aquasport site for him to see if it had been done and how it worked.
I was not sure if the V4 and 19.6 would balance out better than the 222 and V6.
April 09, 2009, 09:48:57 PM
flkeysaqua
« Reply #7 on: April 09, 2009, 09:48:57 PM »
Quote from: "Badonquasport196"
Quote from: "RickK"
That's right 19-6's rule :cheers:
73 19-6 w/140 Evinrude
April 14, 2009, 11:54:12 AM
Treefish
    • http://www.youtube.com/watch?v=rMj9hRafqyQ
« Reply #8 on: April 14, 2009, 11:54:12 AM »
Here's a link to a few pics of a rebuilt 19-6 with a porta bracket by Gause Built Boats. http://www.gausebuiltboats.com/index.cf ... age_key/36
or
April 15, 2009, 10:33:35 PM
« Reply #9 on: April 15, 2009, 10:33:35 PM »
Quote from: "tunahelper"
I know nothing about that rebuild, but I personally did a 222, and know several others with them (with Portas) with zero problems.  These boats are almost made for a porta bracket.  Now 19'6, I have not seen as many... and am making no statement to that effect.
Call Gause about their 19'6, they are friendly folks and will most likely oblige.
April 16, 2009, 10:25:37 PM
« Reply #10 on: April 16, 2009, 10:25:37 PM »
I wonder where that boat ended up? I'd really like to know how it handles with that 150 back that far, like he said the fulcrum point on a 19-6 would probably have to be moved even farther forward than on a 22-2. But man what a sweet ride!
April 16, 2009, 10:26:47 PM
« Reply #11 on: April 16, 2009, 10:26:47 PM »
Quote from: "LilRichard"
I have a full bracket on my 222.
I did move the batteries under the console. That equates to 126 lbs.+/- off of the stern.
Plus the flotation in the bracket motor mount helps also.
I have trim tabs but they're only down 40% when taking off and usually remain there until the sea kicks up.
Mine does not porpoise.
To make matters worse, I installed a live well (17 gal) on the starboard side of the bracket so when full of water, I'm right back where I started.
Still no porpoising.
It must be the hull design.
May 02, 2009, 09:52:34 AM
Treefish
« Reply #12 on: May 02, 2009, 09:52:34 AM »
Just replying to keep this thread active.
I'd also like to hear some first hand accounts of a porta bracket on the back of a 19-6.
May 29, 2009, 02:06:46 PM
dleibman
« Reply #13 on: May 29, 2009, 02:06:46 PM »
I have a 200 Osprey with a Bob's jackplate, poling platform, 40 gal livewell at the transom. Battries (4) inside console. Running a 150hp. Planes very quickly, run tabs up most of time. Rock solid ride. Look at post (TRICKED OUT OSPREY). Love the boat. :salut:
