Fuel tank foam
Topic: Fuel tank foam (Read 1542 times)
July 06, 2005, 03:35:37 PM
Read 1542 times
Mark Sr
Fuel tank foam
July 06, 2005, 03:35:37 PM »
To replace the foam around your fuel tank, does it come in a spray can like the foam you spray to insulate windows?
Mark Sr
July 06, 2005, 04:24:04 PM
Captain
July 06, 2005, 04:24:04 PM »
I believe foam does come in a can or other form that expands when applied. I've been told to be very careful applying it, as the stuff is pretty powerful and if you put too much in a confined area, it will bust through any weak spots.
Tampa - 1976 Aquasport 222
ClassicAquasport.com Co-Founder
Attorney-at-Law
July 08, 2005, 05:32:30 AM
Anonymous
Guest
July 08, 2005, 05:32:30 AM »
I bought my foam at my fiberglass supply house and it comes in 2 parts that you mix and pour into the area. Make sure you mix "just enough" (unlikely to know without a lot of experience) or have an expansion route/hole or like Captain says, it'll cause unseen/unknown problems like pop your floor loose or ....
July 08, 2005, 10:49:47 AM
DEFIANT
Guest
July 08, 2005, 10:49:47 AM »
When I was mixing some two part foam (Evercoat Foam-It Flotation Kit) it took me by surprize! I mixed it as directed and with no warning within about 20 seconds it reacted like a volcano erupting! Foam boiled up all over the place! It was a mess, but also entertaining!
I recomend mixing small batches right where you plan to put it.
Good Luck!
July 11, 2005, 08:07:40 PM
Anonymous
Guest
July 11, 2005, 08:07:40 PM »
Can you get foam mix at Boaters World?
July 12, 2005, 05:35:11 AM
July 12, 2005, 05:35:11 AM »
I haven't tried Boater's World - look for a fiberglass dealer in your area.
August 13, 2005, 02:35:17 PM
warthog5
August 13, 2005, 02:35:17 PM »
Be aware that you DO NOT want to use the foam in a can for foaming a tank. Most of the 2part foam's in the marine store's are 2lb density.
For foaming in a tank you want 4ld density.
A gal kit of 2lb density make 8cuft of foam.
Agal kit of 4lb density makes 4cuft of foam.
You can buy the 4lb density from fgci.com
Fiberglass Coating's Inc.
Fuel tank foam
