Author Topic: alarm going off??  (Read 1153 times)
March 22, 2009, 12:01:07 PM
Read 1153 times
alarm going off??
« on: March 22, 2009, 12:01:07 PM »
the alarm on my '96 112hp spl johnson keeps going off in a "beep... beep... beep..." sequence. there's no check engine lights on the tach. engine idles fine, spark on all cylinders, runs 5-6 psi water pressure on the garden hose at 1,000 rpms. its not running hot, temp gauge shows less than 140 degrees, and i can hold my hand on the head for 5-7 seconds. shows plenty of volts. i am :scratch: on this
March 22, 2009, 02:15:35 PM
Marcq
Re: alarm going off??
« Reply #1 on: March 22, 2009, 02:15:35 PM »
Do you have VRO? low oil?
Marc..
March 22, 2009, 02:24:31 PM
« Reply #2 on: March 22, 2009, 02:24:31 PM »
no vro its the spl motor, pre-mix 50:1
March 23, 2009, 06:42:24 AM
Marcq
« Reply #3 on: March 23, 2009, 06:42:24 AM »
Odd because usuallly a beep every other second is a VRO failure
Try this, when the horn is sounding, disconnect the tan wire from the horn. If the sounding continues, the horn is faulty. If not, check the heat sensors at the heads
Marc..
March 23, 2009, 09:28:05 AM
« Reply #4 on: March 23, 2009, 09:28:05 AM »
the alarm comes on after a minute or 2 of running, checked the sensors, there good, the connections were a lil green but cleaned them still have the alarm. ill try the tan wire later today....
March 24, 2009, 10:11:37 PM
bdtsr
« Reply #5 on: March 24, 2009, 10:11:37 PM »
There should be a switch on the fuel pump. This is a vacuum switch that senses a fuel line restriction. Check your fuel lines and filters. Only other alarm is the overheat. When the alarm sounds, disconnect the tan wire to the overheat sensor on the head and check for continuity from ground through the tan wire/sensor. No reading = good sensor, anything else and sensor is bad. Do the same thing on the switch terminals on the fuel pump switch while engine is running and then off. Should only get a reading if you pinch the fuel line while it's running and cause a restriction. Keep us posted.
1978 Aquasport 200 CCP 1990 225hp Yamaha
1990 Bayliner 2302 Trophy 2000 225hp Optimax
1999 Bayliner 1950 Capri Bowrider Merc 3.0 liter I/O
1986 Arrowglass CC w/1986 Evinrude 115hp
3 Kawasaki Tandem Sport Jet skis
1993 Seadoo XP
1988 Yamaha WR500
March 25, 2009, 12:01:23 PM
« Reply #6 on: March 25, 2009, 12:01:23 PM »
i checked the temp switches, the one on port side of the block has no reading, same as starboard. checked on the engine harness side, port side, nothing. starboard side, it shows a reading for a split second then nothing. theres no fuel line restriction, its going directly from a portable tank into the connection on motor, then direct into the fuel pump... if i cant figure it out, away with the alarm! i have a separate temp gauge that works, and water pressure gauge. hell, if an alarm sounds while under way, most of the time i dont even hear it on my other boat. just gotta keep an eye on the gauges. :cyclops:
