Author Topic: Need help picking a prop  (Read 732 times)
March 19, 2009, 09:57:39 AM
Read 732 times
Fishhyren11
« on: March 19, 2009, 09:57:39 AM »
I have an older aluminum prop on my 1984 115 Evinrude on my 1985 170.
Though I'm not certain, I have a feeling this engine has been rebuilt in the past...
My recifyier needs to be replaced, so I can't tell you what my RPMs are running right now.
I have a new rectifyier, but I need to find a shop manual that says how to replace it (looks like I just need a steering wheel puller to get the flywheel off to get to it).
Anyways, I'm wondering how do I figure out what is the best prop for this boat?
The previous owner gave me a SS prop, but it rubs, so it is either too big or needs a spacer?
I'm looking for a balance of speed and hull shot, right now my top end is ~ 36mph   If I'm the only one in the boat and we aren't loaded to the teeth I can get out very quickly, but if we add 3 more people I need them to stand to the front of the boat till I can get up.
Thanks!
March 19, 2009, 09:09:29 PM
Re: Need help picking a prop
« Reply #1 on: March 19, 2009, 09:09:29 PM »
Try this from our resident "prop scars".  :roll:
There's more out there (hell, I even posted on props once) and this is a good starting point. http://www.classicaquasport.com/phpbb3/viewtopic.php?f=5&t=2084&start=0&st=0&sk=t&sd=a&bookmark=1
March 24, 2009, 10:30:16 PM
bdtsr
« Reply #2 on: March 24, 2009, 10:30:16 PM »
Sounds like you have a 19 or 21" pitch prop. Prop for about 5500rpm LOADED. Make sure the motor is trimmed all the down and raise it as you come up on plane. A drop in pitch prop would give a better hole shot but less top speed. The stator is under the flywheel. The rectifier/regulator should be on the port side of the engine with 5 wires or on the top back between the "V" of the engine (if memory serves), 2 yellow, 1 red, 1 black, 1 gray. With the engine running you should have 20-24 volts AC present on the yellow wires, if not the stator is shot. The red and black wires should have about 14 volts DC if the rect/reg is working. Tach not working only points to the stator or rect/reg. The charging output is only 9 amps on these motors so be carefull not to load it too much. It is possible to kill the battery with engine running (killer stereo will do it).
1978 Aquasport 200 CCP 1990 225hp Yamaha
1990 Bayliner 2302 Trophy 2000 225hp Optimax
1999 Bayliner 1950 Capri Bowrider Merc 3.0 liter I/O
1986 Arrowglass CC w/1986 Evinrude 115hp
3 Kawasaki Tandem Sport Jet skis
1993 Seadoo XP
1988 Yamaha WR500
