Author Topic: What is the ideal thickness for a transom?  (Read 717 times)
March 01, 2009, 01:57:23 AM
Read 717 times
drevca96
« on: March 01, 2009, 01:57:23 AM »
Planning on replacing the half transom on the a 1970 22-2 and doing a fully enclosed transom.  I've read the thickness for a transom should be at least 2" but I've seen some rebuilds only using two pieces of 3/4" ply which equals to 1.5".  Is there really an ideal thickness?
March 01, 2009, 01:13:07 PM
Mad Dog
Re: What is the ideal thickness for a transom?
« Reply #1 on: March 01, 2009, 01:13:07 PM »
2" is standard.  1.5" core and 1/4" glass inside and out.
If you are going to a full transom are adding a bracket of some kind?  If so the transom needs additional strengthening, such as knee braces.
MD  :wink:
March 02, 2009, 09:34:35 PM
bdtsr
« Reply #2 on: March 02, 2009, 09:34:35 PM »
When we did the transom on my 23 walk around, we used 3 layers of 3/4 ply glassed prior to being set in, glassed again when set in and clamped/screwed/bolted together. Then reglassed the knee braces in. We had plenty of room to work with inside. The transom was converted from a well with twins to an enclosed transom with a bracket and a single.
1978 Aquasport 200 CCP 1990 225hp Yamaha
1990 Bayliner 2302 Trophy 2000 225hp Optimax
1999 Bayliner 1950 Capri Bowrider Merc 3.0 liter I/O
1986 Arrowglass CC w/1986 Evinrude 115hp
3 Kawasaki Tandem Sport Jet skis
1993 Seadoo XP
1988 Yamaha WR500
