Author Topic: Fuel Tanks ('66 flatback diver rebuild)  (Read 853 times)
February 17, 2009, 10:04:02 AM
Read 853 times
Bhard
« on: February 17, 2009, 10:04:02 AM »
Hey guys.  I'm having a heck of a time finding a decent size tank to fit under the deck of the boat.
What size tanks (capacity and dimensions) have you used?
February 17, 2009, 12:03:17 PM
Re: Fuel Tanks ('66 flatback diver rebuild)
« Reply #1 on: February 17, 2009, 12:03:17 PM »
I bought a custom made aluminum tank, 63 gals.
You will most likely not find a pre-built that will fit under the deck, because the dimensions are very tight.
February 17, 2009, 11:46:06 PM
71flatback
« Reply #2 on: February 17, 2009, 11:46:06 PM »
Tempo makes a 36 gallon plastic tank that fit under my floor, but yours looks lower. It's  68 3/4" x 16"x 8 1/4"
1971 aquasport 22-2 flatback, Work in progress
February 27, 2009, 10:22:13 AM
Bhard
« Reply #3 on: February 27, 2009, 10:22:13 AM »
Still working on the tank issue.  It will definitely need to be a custom tank; I'm really trying to get a 40 gal one in there, but it looks like the tank will need to be about 7' in length to accomplish this. That seems long to me....  What do you guys think?    The boat's original stringers started tall in the front and slowly shortened as they went aft, because of the "flatback".  Even if we raise the floor an inch, the deepest tank we could probably go is 6.5".  I'm starting to wonder if it's worth it, but most importantly, I want to make sure that we're not compromising the strength of the hull by making that big of a coffin for a skinny tank.      Any feedback?
February 27, 2009, 02:37:59 PM
Mad Dog
« Reply #4 on: February 27, 2009, 02:37:59 PM »
Try these guys, http://www.speedytanks.com/
Built to your specs and ready to install when they arrive.
MD  :wink:
March 01, 2009, 09:47:45 AM
« Reply #5 on: March 01, 2009, 09:47:45 AM »
I have your exact hull, and fit 63 gallons under the deck.  How far apart are you putting your stringers?  As I recall (these are only from memory, I can look up actual dimensions) my tank was something like 60" long by 30 or 32" wide by 7" deep.  I had them put a VERY slight vee in my tank.  The builder advised it would allow the pickup to access more fuel than a completely flat tank.  I think the middle is 1" deeper than the sides... resulting in less unusable volume.
You need at least 40 gallons on that boat, IMHO.   I would want to be able to run at least 4 hours.  You will have anywhere from 10-20% of the tank that is unusable.  40gals X 80% = 32gals.  Assuming you are running a four stroke that burns 8 gals/hr, that means 4 hours run time.
March 02, 2009, 12:17:00 PM
Bhard
« Reply #6 on: March 02, 2009, 12:17:00 PM »
Thanks for everyone's input!  It's great having a clean slate to work on, so I told Brien to go ahead with the stringers and we ended up with more width between the stringers than originally anticipated.  So we'll be able to shorten the tank and still get at least a 40 gallon tank in there.  Again, thanks.
