Author Topic: 73 19-6 little by little  (Read 16814 times)
July 30, 2011, 09:05:56 PM
Reply #180
flkeysaqua
Re: 73 19-6 little by little
« Reply #180 on: July 30, 2011, 09:05:56 PM »
Thanks for the welcome back Gran sounds good I'll have to look back it's been awhile since I saw that post.  To my other question I could pour it twice without too much trouble.
73 19-6 w/140 Evinrude
August 02, 2011, 10:29:43 AM
Reply #181
naytep
« Reply #181 on: August 02, 2011, 10:29:43 AM »
I have a 78 196 cuddy. Couldnt help but notice yours had the same crack at the top of the transom. I didnt read all 13 pages of the post so I may not be following exactly. But how did the repair work out from your first pics (less the stitches in finger)? Mine was sealed with marine sealant so I dont think to much water got into it.
Hungarian Hooker
78\' Aquasport 196, 150 Evinrude
August 04, 2011, 12:01:14 AM
Reply #182
flkeysaqua
« Reply #182 on: August 04, 2011, 12:01:14 AM »
First thing I did was ground all the old spots that were repaired incorrectly i.e. filled with 5200 which included the crack on the transom.  All the old screw holes were also drilled out a few sizes bigger and filled with hardwood dowels that were soaked in resin then glasses over. Hope this helps.
P.s. if you use a 40 grit flap wheel don't get to close :shock:
