my 175 mercury 2008 model weighs in at 430 pounds out of box. good hp to weight ratio.
Sweet that's what I like about this site exact info quick Badonquasport196 I haven't really experienced any backwash coming off plane at all on the 19-6 and I'll drop right off plane but it definitely gets close with only the 140 on there so I would really suck more gas even if my rpm speed drop alot say I run at 4,500 now at 30-33 mph and with the 200 I run 3,500rpm to get the same speed wouldn't that compensate for the extra mpg? Also I thought I could definatley be wrong but a 175 yammy was the same weight as a 200? So I would be better off if I did repowered to go with a 200 instead of a 175?
Close to the top of the transom? No I'd say level the waterline is even with the center of the scuppers. Oh do you have the transom mounted livewells? If so what do you think of them wondering if it is a pain in the going over the transom everytime you want some bait.
No, I didn't mean the water was close to the top of the transom, I meant close to coming in through the scuppers. I don't have the stern mounted livewells, but I used to on a 17' Aquasport I used to have, and I think it was somewhat of a pain ... best I can remember.No comment on Capt. Bob :)
Just curious, what is the main reason(s) you want to re-power with a 200hp? Will it be loaded down with fish, people, material? I personally feel something around a 150hp would be more than enough power.There use to be a guy on here (woody) who had a 19-6 with a 200hp. Maybe he could help.
Also are the transom live wells made from glass and how big are they? (not trying to steal them from Badobquasport196 ) just thinking of either building a set. Oh what do you gentlemen think about the pro's and con's of mounting a motor on a outboard bracket is it even worth the time and effort? The rod holders under the gunwale I only have one under the port side are all the others the same shape, dimensions etc. as that one? I'll post a pic when I can once again thanks in advance for the help
Cool thanks if you decide to upgrade your rod holders would you be interested in selling them? :bounce: thanks for the link
