Marc,I'll see the boat everyday and sole/deck is watertight. The lid over the fuel tank is caulked and the bolts for the seats are caulked and the bilge isn't getting any water in it on the trailer.
That's really a tough call. I know it is not reasonable, but the right way to do that is to raise the deck. If you plug the scuppers, you are obviously relying on just mechanical pumps... which I don't trust.If you do go that route, I would have a few pumps, and wire them to separate batteries on separate switches. Not saying that is ideal, but it at least helps.
Quote from: "jethrosixxx"Marc,I'll see the boat everyday and sole/deck is watertight. The lid over the fuel tank is caulked and the bolts for the seats are caulked and the bilge isn't getting any water in it on the trailer.Then I wouldn't worry about it, just use those brass/rubber plug to plug those scuppers temporaly(when you're not there), of course, unless the forcast is for 3 inches of rainMarc..
Quote from: "LilRichard"That's really a tough call. I know it is not reasonable, but the right way to do that is to raise the deck. If you plug the scuppers, you are obviously relying on just mechanical pumps... which I don't trust.If you do go that route, I would have a few pumps, and wire them to separate batteries on separate switches. Not saying that is ideal, but it at least helps.wouldn't glassing over the existing scupper holes and cutting new, higher ones have a similar effect?
If you raise the scuppers 1.5", then you'll have to build 1.5" of water before they drain, right? By then, I will bet the boat will have squatted 1.5" due to the weight of the water, again placing the scuppers below water level.
..T-H Marine Flow Max Ball Scupper :You can buy it here : http://www.boatersworld.com/product/356975243.htmHope this helps ! :viking:
