Author Topic: Navitronics map SD card do I need one for hummingbird 595c  (Read 960 times)
February 10, 2009, 11:08:45 PM
Read 960 times
flkeysaqua
« on: February 10, 2009, 11:08:45 PM »
Do I need a Navitronics map SD card for a hummingbird 595c combo gps/depth finder or are the base maps enough I'm in the Flroida Keys and have lived here my whole life and the lowest I've found it was $375 on Amazon new not refurb any recommendations on different models And should I go with transom mount hull mount or threw hull which scares the hell out of me just thinking about cutting a hole in the bottom of my 73 19-6 never owned a fish finder only gps I have is a handheld but thinking of upgrading and this looked like a good deal for the options any feedback would be appreciated
73 19-6 w/140 Evinrude
February 11, 2009, 07:42:31 AM
Re: Navitronics map SD card do I need one for hummingbird 595c
« Reply #1 on: February 11, 2009, 07:42:31 AM »
The Navitronics cards are awesome!  You bet all the markers, buoys, fish attractors, etc.  Way more usefulness that the built-in map the comes with the 595.  Keep an eye on the specials with West or BassPro - also check out eBay - lots of SD cards there:
http://shop.ebay.com/items/__navionics- ... Z15QQ_scZ1
See ya on the water!
February 11, 2009, 03:15:09 PM
DOCREED
« Reply #2 on: February 11, 2009, 03:15:09 PM »
Navionics makes fishing cards as well. (Fishing Chips) They show alot more bottom detail and bathy lines than the Navionics regular navigation chart cards.
Any outboard boat can use a transom mounted transducer.  With a low powered fishfinder, there is no gain with a thru hull transducer.
On a small boat with a relativley thin hull, you might try a glue in transducer.  You will loose surface water temp and speed thru the water with this type of transducer, but no holes anywhere are required.
89 250 CCP
full transom
February 11, 2009, 10:43:12 PM
flkeysaqua
« Reply #3 on: February 11, 2009, 10:43:12 PM »
Thanks for the input but for those prices I'm hoping a friend of mine will have the one I need I can't see spending 200 bucks on a chip I might have a change of heart once I get the system If I go with the hull mounted transducer will I lose alot of clarity I guess is was I'm wondering and what if I went with transom mounted instead of screwing the cable down couldn't I 5200 it inplace?
