Author Topic: Fuel Tank Grounding?  (Read 1312 times)
June 25, 2005, 10:52:40 AM
Read 1312 times
pbailey
« on: June 25, 2005, 10:52:40 AM »
Had the fuel tank hatch cover off and noticed that there was a black wire attached to a strap on the gas tank.  The tank is original and is constructed out of aluminium.
Where should this wire be landed?  Does it connect to the battery - terminal?
Thanks,
pbailey
June 25, 2005, 09:44:04 PM
« Reply #1 on: June 25, 2005, 09:44:04 PM »
Yes, ground it, which on most boats is the battery Negative.
http://www.uscgboating.org/safety/boatb ... 83-572.htm
June 26, 2005, 12:33:40 AM
pbailey
« Reply #2 on: June 26, 2005, 12:33:40 AM »
John,
Thanks,
I will get it grounded right away, I will also check the deck fitting.
Thanks again.
pbailey
June 29, 2005, 11:26:10 PM
pbailey
« Reply #3 on: June 29, 2005, 11:26:10 PM »
John,
Thanks again for the tip.  I checked to see if the fill cap and neck was grounded as it's made of metal.  When I was working in that area, there was a small hint of gas fumes.  The cap and neck had a ground wire that was twisted around the wire reinforcement of the fuel line, but that was all.
As I was taking it apart, I found the vent line to be dry rotted and the first 10 -inches of the fill line nearly fell apart in my hands.  The outside of the fill line was almost in a gel like condition.
Went and picked up some fuel fill and vent line and installed that today.
While I was at it I properly grounded the tank and fuel fill fitting.
Those of you who are picking up these old AS might want to check the fuel systems.  When I had the tank cover off everything looked good at the tank end.  The fill end was another matter.
Thanks Again,
pbailey
June 30, 2005, 08:21:34 AM
wmchurch
« Reply #4 on: June 30, 2005, 08:21:34 AM »
It's never a bad idea to replace the fuel and vent lines if you don't know their history... One thing you don't want is a bilge full of fuel!
If everything looks good, it's a good idea to check the continuity of the ground on the fill ports and tank, make sure they meet up with the battery ground.
I also like to double clamp hoses, especially fuel lines and through hull fittings.
Bill Church
Saint Petersburg, Fl
1979 Aquasport 200CCP
