Author Topic: Ceiling material  (Read 592 times)
January 21, 2009, 05:25:05 PM
Read 592 times
Double Trouble
  • NorthEast
Ceiling material
« on: January 21, 2009, 05:25:05 PM »
Hi Bob hope all is well.Ihavenot been down to the boat to work on my power problem we have been discussing in my no power tread yet the weather up here in NY has been brutal, getting a little break thurs. and fri. hope to figure it out then.I do have another question regarding the 2000 275 explorer,Iam going to hang some storage cabinets over the upper bunks which are not to useful any way can you tell me the material of the cabin ceiling in that and if it will hold screws.I will try and post pictures by the way the cabinets are custom cherry wood that I built I am a retired carpenter and need to use my tools every once and awhile.I will post some pictures soon.
                                          DT
January 21, 2009, 10:07:49 PM
Re: Ceiling material
« Reply #1 on: January 21, 2009, 10:07:49 PM »
DT,
I assume this post was intended to me.  Your cabin top and walkaround should be cored with 3/4" end-grain balsa, but might be 1/2"  Are these what your cabinets will resemble?  Walk-Around Cabinets.  This is a set on a 37 Stamas.
January 22, 2009, 03:27:45 AM
Double Trouble
  • NorthEast
« Reply #2 on: January 22, 2009, 03:27:45 AM »
Thanks for the info. Seabob The cabinets on the starboard have doors port side have drawers.They are 36" long on each side.
January 22, 2009, 04:21:18 PM
« Reply #3 on: January 22, 2009, 04:21:18 PM »
DT,
Some tips that I saw the Stamas carpenters use.  1)  When you get the cabinets fit, jack them up to fit them in place with bottle jacks at each end to support and hold in place.  2)  Locate where you will be screwing through the tops of the cabinets into the coring of your walkaround.  Mark the location with a light pencil line.  3)  Remove the cabinets and pre-drill clearance holes (3/16" for #10 screws) and countersink for Ovalheads.  4)  Re-locate, secure in place, pre-drill the walkaround, secure, and your good to go.  Just make sure you don't tweak the frames, or the doors and ESPECIALLY the drawers will bind like a SOB.  But you already knew that, didn't you?
January 22, 2009, 04:37:17 PM
Double Trouble
  • NorthEast
« Reply #4 on: January 22, 2009, 04:37:17 PM »
I have used that setup before it works very well another set up is to use 2 pieces of wood furring cut slightly longer then the height and wedge from opposite directions to prevent slipping. Thanks for the heads up. :bounce:
January 22, 2009, 04:43:59 PM
« Reply #5 on: January 22, 2009, 04:43:59 PM »
DT,
Now I'm not a carpenter, but I did stay at a Holiday Inn Express last night! :D
January 22, 2009, 05:13:51 PM
Double Trouble
  • NorthEast
« Reply #6 on: January 22, 2009, 05:13:51 PM »
Your qualified. :compress:
January 22, 2009, 05:50:24 PM
« Reply #7 on: January 22, 2009, 05:50:24 PM »
That's scary... :bball:   GO MAGIC!!
