Author Topic: Masking tape  (Read 1077 times)
December 28, 2008, 06:14:26 AM
Read 1077 times
Double Trouble
  • NorthEast
Masking tape
« on: December 28, 2008, 06:14:26 AM »
I am Ready to start redoing the non skid areas on my boat.Decided to go with Interlux Perfection they recommend up to 12 hours between coats do I have to remove tape after each coat or imeadiatly after final coat. :roll:
                                          Thanks for your input guys
December 28, 2008, 07:57:29 PM
Mad Dog
Re: Masking tape
« Reply #1 on: December 28, 2008, 07:57:29 PM »
Use the blue painter's tape and you'll have no problems.
MD  :wink:
December 29, 2008, 04:22:17 AM
slippery73
Re: Masking tape
« Reply #2 on: December 29, 2008, 04:22:17 AM »
I usually use green 3m tape for tape offs when painting something, its fine line tape. Wont let paint seep under edge when rolling or spraying.
December 29, 2008, 01:32:24 PM
Double Trouble
  • NorthEast
Re: Masking tape
« Reply #3 on: December 29, 2008, 01:32:24 PM »
Maybe my question was not clear. Must I take the tape off after each coat or do I leave it in place until final coat is done some 12 hours later.
                                            Thanks again
December 29, 2008, 09:16:02 PM
slippery73
Re: Masking tape
« Reply #4 on: December 29, 2008, 09:16:02 PM »
Not sure what to tell you on that, havn't used that paint. I generally remove tape after paint has kicked but hasn't cured. Otherwise some paints tend to lift at the tape line if left to cure. I'd check the product specs and see what it says. You might have to use a special tape to mask off, 3m makes specialty tapes just for such things.
December 30, 2008, 04:08:06 AM
Double Trouble
  • NorthEast
Re: Masking tape
« Reply #5 on: December 30, 2008, 04:08:06 AM »
Thanks for the help All.
December 30, 2008, 05:24:27 AM
Re: Masking tape
« Reply #6 on: December 30, 2008, 05:24:27 AM »
You could also try this approach, works great.
January 09, 2009, 06:14:10 AM
Double Trouble
  • NorthEast
Re: Masking tape
« Reply #7 on: January 09, 2009, 06:14:10 AM »
OK I painted my non skid used the perfection by Interlux very happy with results the product is all they say,as far as the masking tape used 3M fine line left it on over night betwee coats removed about an hour after final coat had no problem left nice crisp edges.If anybody needs interlux products try wholesale marine cheapest I have found :bounce:  :bounce:
