Props
High Five prop
Topic: High Five prop (Read 1507 times)
December 03, 2008, 11:43:41 PM
Read 1507 times
Mike Answeeney
High Five prop
December 03, 2008, 11:43:41 PM »
I just pick up a High Five prop off of Ebay (13.5x17). :santa: I currently have a 14.5x18 four blade and about 500rpm to spare. I'll let ya know how it works for my setup.
Mike Answeeney
1973/2008 22’2
Aquaholic
December 04, 2008, 03:47:49 PM
December 04, 2008, 03:47:49 PM »
Let me know how you like it. I put a PowerTech on mine and it is awesome. I can come onto plane fully jacked up (ventilating, but nonetheless). It bites well - seems to hold better than some other props I have seen on 222s.
If you have any questions, talk to Ken at PropGods - great guy, patient, knowleageble.
December 05, 2008, 07:05:40 PM
Re: High Five prop
December 05, 2008, 07:05:40 PM »
I've been very happy with the HighFive on my CCP - I'm using a 19 pitch with my 200 Merc, turning 5500 and 43 MPH top end...
December 20, 2008, 12:14:02 PM
Mike Answeeney
Re: High Five prop
December 20, 2008, 12:14:02 PM »
So I installed the prop but there is much more z axis movement on the shaft than the other prop. Do i need to add some washers behind the shaft bolt?
Mike Answeeney
1973/2008 22’2
Aquaholic
December 20, 2008, 06:32:18 PM
slippery73
Re: High Five prop
December 20, 2008, 06:32:18 PM »
You will need to get a thrust washer for it, should be able to get one from a prop shop no problem.
December 21, 2008, 10:32:07 AM
Re: High Five prop
December 21, 2008, 10:32:07 AM »
Nice diagram and installation info here:
http://www.propline.com/Propeller-Gener ... lation.htm
December 24, 2008, 01:24:38 PM
Mike Answeeney
Re: High Five prop
December 24, 2008, 01:24:38 PM »
After going out and buying a thrust washer, I find that there is already one on the prop shaft.
So with the thrust washer installed, there is still about 1/4 inch play in the prop mounting and it's because the splines on the shaft extend 1/4 inch beyond the face of the prop hub. When I tighten down the prop nut, it hits the slines before it hits the hub face.
Would a simple washer behind the prop nut be a resonable solution or is that just a bandaid for another problem?
Mike Answeeney
1973/2008 22’2
Aquaholic
December 25, 2008, 11:19:56 PM
slippery73
Re: High Five prop
December 25, 2008, 11:19:56 PM »
You need a special thrust washer for that prop, my aluminum stock prop had a different washer than my aftermarket stainless.
December 26, 2008, 07:48:14 AM
Re: High Five prop
December 26, 2008, 07:48:14 AM »
New prop should come with a new thrust washer...
See ya on the water!
December 27, 2008, 01:00:37 PM
Mike Answeeney
Re: High Five prop
December 27, 2008, 01:00:37 PM »
Thanks for the feedback guys.
Mike Answeeney
1973/2008 22’2
Aquaholic
June 28, 2009, 12:43:23 PM
Mike Answeeney
Re: High Five prop
June 28, 2009, 12:43:23 PM »
I finally put some numbers together.
1973, 22-2 Aquasport, with a 2003 175 Optimax on a Portabracket. T-Top installed.
On flat calm day, trim tabs up, 3/4 tank of gas (70 gallon tank), just me (~200lbs) in the boat with the high five prop (13.5"x17).
Once on plane, Portabracket adjusted up for minimal drag.
WOT - 42.2mph on GPS at 5800rpm, 18.4gph
35mph @ 4800rpm, 9.2gph
30mph @ 4300rpm, 7.1gph
28.3mph @ 4000mph, 6.26gph
26mph @3800rpm, 5.56gph
Time to plane, ~4 sec.
Mike Answeeney
1973/2008 22’2
Aquaholic
June 29, 2009, 10:50:30 AM
Re: High Five prop
June 29, 2009, 10:50:30 AM »
That's 4.7 miles per gallon at 26 MPH. Pretty good! My old 2 stroke Black Max is about 3.2 MPG at that speed. Aquasports seem to optimize (OK - Mercury pun there!) around 25-26 miles per hour.
Interesting your 222 has almost identical WOT numbers as my CCP, 18GPH and about 43MPH - probably just hull drag...
Props
High Five prop
