Engines & engine woes
Oil on motor
Topic: Oil on motor (Read 1127 times)
November 26, 2008, 04:54:23 PM
Read 1127 times
allen456
Oil on motor
November 26, 2008, 04:54:23 PM »
Anyone know what is causing oil to leak out of the motor from the lower cowling. This is a 1981 Johnson 175. Let me know what ya'll think.
1979 Aquasport 200 CCP--1981 Johnson 175
November 26, 2008, 05:32:47 PM
November 26, 2008, 05:32:47 PM »
I'm not sure if they had VRO back then. If they did, then I'd check the tank and connection. If not, what ratio of gas to oil mixture you using? 50:1?
Seems normal to have a little fuel/oil mixture dripping out of the carbs. Haven't seen it that black before though. Maybe try some "purple stuff" to clean it off and then watch it.
November 26, 2008, 07:24:59 PM
allen456
November 26, 2008, 07:24:59 PM »
When I picked up the boat there was no sign of this a couple of weeks ago(then again it hadn't been run in a few years) This is a basic 2 stroke that I mixed 50:1 on the first run and 45:1 on the second due to the excessive smoke(even for a two stroke). I am open to options here. There are not any sign of the oil near the carbs or in the upper cowling.
November 26, 2008, 07:57:36 PM
slippery73
November 26, 2008, 07:57:36 PM »
Any smoke coming out of the top area of the motor? A lot of times the water passages will get corroded out and let exhaust and water exit where its not supposed to. Check for corrosion under the hood areas, also pull the spark plugs and check them out.
November 27, 2008, 02:24:00 PM
allen456
November 27, 2008, 02:24:00 PM »
I have seen a little smoke out of the top everyonce in a while, thought that it was just the way the smoke was blowing around with the motion /wind. The plugs show a little sign of extra oil but nothin crazy. Are there seals under the lower cowling?
January 12, 2009, 12:05:47 AM
bdtsr
Re: Oil on motor
January 12, 2009, 12:05:47 AM »
What slippery73 said. Looks like oil residue from an exhaust leak.
1978 Aquasport 200 CCP 1990 225hp Yamaha
1990 Bayliner 2302 Trophy 2000 225hp Optimax
1999 Bayliner 1950 Capri Bowrider Merc 3.0 liter I/O
1986 Arrowglass CC w/1986 Evinrude 115hp
3 Kawasaki Tandem Sport Jet skis
1993 Seadoo XP
1988 Yamaha WR500
January 22, 2009, 10:38:26 AM
gw204
Re: Oil on motor
January 22, 2009, 10:38:26 AM »
Could also be the lower crankshaft seal. Can you get those two pieces of bottom cowling off so you can get a look at the base of the powerhead?
Brian
St. Leonard, MD
1981 Mako 17
1986 Grady White 227
February 12, 2009, 09:59:56 PM
allen456
Re: Oil on motor
February 12, 2009, 09:59:56 PM »
Took the lower cowling off, and took show pics, let me know waht you think.
Oil on motor
