Yeah, I would definitely pull the tank. Looks pretty dirty in there, even if nothing is wrong with the tank, it would give you peace of mind to know that the tank's clean on the inside and at least leak-proof. My tank had the original tank mounted fuel guage. I replaced it with a sending unit... much nicer.On a different note: Looks like your 19-6 has the stern mounted livewells. I'm jealous! :x I didn't know if they made them for the 19-6, but I guess so. If you get a chance, could you possibly post some pics of the livewells? Also, I like the black bottom paint. I'm about to repaint the bottom of mine black; it's nice to get an idea of what it would look like.... Definitely better than the green that's on mine now.Nice Boat.
I'm looking at buying a 1974 17' that has some soft spots in the floor, it will need to be replaced at some point. Is it setup the same as this 19?
How are the stringers? All still attached well, no cracks?If so, you have a pretty straight forward job to do... should be relatively easy. Good call on pulling the tank - I certainly would.
