Author Topic: '72, 22-2 original stringers question  (Read 1149 times)
November 19, 2008, 05:09:43 PM
Read 1149 times
love2fish
« on: November 19, 2008, 05:09:43 PM »
Is there a strip of thicker fiberglass on the hull side of the stringer to hull joint of your original stringers? My stringers have seperated/cracked in several spots along the "outside" of the port and starboard stringer in my 72, 22-2. Thanks
Chris
\'74 22-2
Member #921
November 19, 2008, 07:50:51 PM
jupitermike1
« Reply #1 on: November 19, 2008, 07:50:51 PM »
My stringers are glassed half way up on the outboard sides with heavy woven &  all the way to the top in my engine compartment inboard & halfway up the rest of the way. I have one spot of delam on the inboard side to the hull. Also some cracking & crush spots on the top corners in a few spots. I will begin some patches as soon as I finish removing wet foam in other stringer.
1975 22-2 inboard
November 19, 2008, 08:18:59 PM
love2fish
« Reply #2 on: November 19, 2008, 08:18:59 PM »
Mike, do you care if I stop by sometime to take a look at your boat?
Chris
\'74 22-2
Member #921
November 19, 2008, 10:31:03 PM
« Reply #3 on: November 19, 2008, 10:31:03 PM »
How bad is the separation?  Are the stringers broken at all, or just pulling away from the hull?
November 20, 2008, 07:37:02 PM
jupitermike1
« Reply #4 on: November 20, 2008, 07:37:02 PM »
Sure you can come by & take a look give me a call @561-758-5226
1975 22-2 inboard
November 20, 2008, 08:50:26 PM
love2fish
« Reply #5 on: November 20, 2008, 08:50:26 PM »
the stringers are in good shape, no cracks, dents, anywhere. The only bad spots are on the top edges near the foam fill holes where the fiberglass appeared to be thinner than on the sides.
The seperation seems to be limited to the 4" fiberglass tape in the immediate joint of the stringer and hull.  its consistant and only on the "outside" of the stringers.
Chris
\'74 22-2
Member #921
November 20, 2008, 10:10:42 PM
« Reply #6 on: November 20, 2008, 10:10:42 PM »
Grind it, add a filet, more glass, and forget about it.
