191 Rebuilds
Ideas on reenforcing gunwale cap
Topic: Ideas on reenforcing gunwale cap (Read 1792 times)
November 18, 2008, 09:34:58 PM
Read 1792 times
davis74
November 18, 2008, 09:34:58 PM »
I have a 1971 19-1. The gunwale cap or washboard really bows down when I step down on it from the dock. The under gunwale rod holders were removed when I bought the boat were those supports? I would like to hear your ideas on fixing the problem. Thanks
November 18, 2008, 10:21:21 PM
Mad Dog
November 18, 2008, 10:21:21 PM »
Davis, I would refit brackets to replace the rod holders. On my rebuild, I recored the cap with 1/2" ply and added the same 1/2" inside the cap facia (?). There was nothing providing verticle support on my 22-2. Now it is very stiff under my 200#.
MD
http://s175.photobucket.com/albums/w150 ... Aquasport/
November 19, 2008, 10:40:53 PM
November 19, 2008, 10:40:53 PM »
Mad Dog - there is no core in a 1971 hull, so you would have to add a core. That's a good way to go, but requires you remove the cap.
I went with gussets every two feet with a few hullside stiffeners that went all the way from the floor up to the cap. You can see the stiffeners here:
Here's a shot showing the smaller gussets:
November 21, 2008, 09:03:32 PM
davis74
November 21, 2008, 09:03:32 PM »
That looks really nice. What did you use to build the stiffeners? Thanks for the help.
November 21, 2008, 09:19:53 PM
November 21, 2008, 09:19:53 PM »
Thanks.
They're just glass over foam. Start with 3lb polyurethane foam, shape to fit, then lay two or three layers of 1808 over it.
November 23, 2008, 06:04:12 PM
compcrasher86
November 23, 2008, 06:04:12 PM »
I am in the same predicament, I actually found two out of four rod holder assemblies thrown inside the hull (weird?) so I am taking them out, tracing to make two of each (yeah they're so beat up they wont be going back in) , and rebuilding with the classic stain and varnish appearence
Stock 1973 222 Open Fisherman
"Floor it"
November 23, 2008, 07:43:09 PM
davis74
November 23, 2008, 07:43:09 PM »
Do the rod holders add support? LilRichard thanks for the info I think I am going to try to copy that.
November 30, 2008, 08:40:18 PM
davis74
November 30, 2008, 08:40:18 PM »
LilRichard when you said "3lb polyurethane foam" I assume you mean foam board not liquid 2 part foam? Do you know a good place to buy or order from? Is there a name (brand) for the foam? Thanks
December 01, 2008, 04:50:07 PM
December 01, 2008, 04:50:07 PM »
Yes, foam board. I do not think there is a brand - I bought mine from FGCI. You can also try Composites One.
You don't need a structural foam, the strength comes from the glass. And the 3lb variety is easily shaped.
191 Rebuilds
