Flatback 22-2 Rebuilds
newbie with a 22.2 FB w/pics.. update 2/16/09
Topic: newbie with a 22.2 FB w/pics.. update 2/16/09 (Read 3579 times)
February 16, 2009, 12:36:56 PM
love2fish
Re: newbie with a 22.2 FB w/pics.. update 2/16/09
Reply #15 on:
February 16, 2009, 12:36:56 PM »
What was wrong with the exterior skin on the transom?
Chris
\'74 22-2
Member #921
February 16, 2009, 01:14:23 PM
David B.
Reply #16 on:
February 16, 2009, 01:14:23 PM »
Well, whoever had this boat before me tried to rebuild the transom. In between the outershell and the wooden transom was a mix of epoxy, glass and ceramic compound of some type. I tried chiseling, cutting, hammered for 2 days tryin to remove it before i decided to just cut it all out. Im not sure which way to go with the new transom. Either a plywood (marine grade) or a ceramic compund type or seacast?! Has anybody ever used a ARJAY (pourable ceramic compound) for a rebuild?
1970 22.2 FB
no power!
February 20, 2009, 09:25:32 AM
Reply #17 on:
February 20, 2009, 09:25:32 AM »
Have not used it, but here Arjay is the stuff. I personally used Marine plywood, only because the pourable was not as popular when I was rebuilding. Either will work though.
BTW, I am in N Tampa, let me know if you would like to see a finished product.
February 20, 2009, 03:00:56 PM
David B.
Reply #18 on:
February 20, 2009, 03:00:56 PM »
LilRichard, Absolutely! Email me your number and we'll chat..:
xxdbesse@yahoo.com
Now, as for the ARJAY stuff I just now got the pricing on that!
I DEF might go with the Marine plywood!
1970 22.2 FB
no power!
February 21, 2009, 10:27:45 AM
Reply #19 on:
February 21, 2009, 10:27:45 AM »
You have email!
March 24, 2009, 10:49:02 AM
David B.
Reply #20 on:
March 24, 2009, 10:49:02 AM »
Not a whole lot, but its moving along.
scrub, wash and degreasing the hull.
A few days later, here I'm adding 2 layers of 1808 to help reinforce it some.
First one was about 7" wide (3.5" up the wall & 3.5" along the bottom) and the second layer was about 14".
Playing with the soon-to-be new strings.
Haha.. my gf wanted to help out. She had no idea what she was getting herself into!
1970 22.2 FB
no power!
March 24, 2009, 12:39:56 PM
Reply #21 on:
March 24, 2009, 12:39:56 PM »
One thing I would have done differently: if your keel seems weak, or has ANY indication of water intrusion, do a little grinding from inside the hull and see what you have. If necessary, repair from the inside. Mine had some slight signs (that I did not address) and I ended up having to repair from the outside - requiring MUCH more fairing work.
March 24, 2009, 02:02:29 PM
David B.
Reply #22 on:
March 24, 2009, 02:02:29 PM »
LilRichard, your right absoluteky right about that. It felt a lil weak towads the bow so I layed down a few layer of 1808 ( 4 layers total) and one layer down the center of the keel. But I think Im gonna lay down one more over laping the other just as in case!
1970 22.2 FB
no power!
March 24, 2009, 08:47:50 PM
Reply #23 on:
March 24, 2009, 08:47:50 PM »
Yup. I did the same thing: here's the problem though... the core could be toast. You may be ok, you'll know when you start working on the underside - see how it looks. If it has a lot of stress cracks, you should probably do what I did - reinforce from the outside of the hull too.
Also, don't forget to extend the keel 4 ft toward the aft... it will make the hull handle MUCH better in turns!
Good luck, keep chugging along!
March 24, 2009, 09:24:13 PM
Marcq
Reply #24 on:
March 24, 2009, 09:24:13 PM »
Quote from: "LilRichard"
That's a cored hull ?
Marc..
March 24, 2009, 11:07:15 PM
Reply #25 on:
March 24, 2009, 11:07:15 PM »
No sir - I should have been more clear: the keel has a core. Mine was actually some sort of composite (I think it was more or less solid resin/fibers) but I do believe some keels may have been wood. Make sense?
March 25, 2009, 09:28:37 AM
David B.
Reply #26 on:
March 25, 2009, 09:28:37 AM »
Yeah, I figured the inside was gonna be a cake and the underside was gonna be a different story!
Hey LilRichard, what are your plans this weekend? I would like to stop by and take a look at your FB.
1970 22.2 FB
no power!
March 25, 2009, 03:57:29 PM
Reply #27 on:
March 25, 2009, 03:57:29 PM »
Out of town actually - but I am around this week. If you want to stop by, shoot me an email / PM.
