Author Topic: leak fuel -- manifold and carbs  (Read 746 times)
November 03, 2008, 03:05:13 PM
Read 746 times
jsakat1
« on: November 03, 2008, 03:05:13 PM »
I have a 90 HP mercury on the boat now. Haven't taken it out. But I am seeing that on idle and revved up that fuel is coming out of the carb is connected to the intake manifold (induction manifold). The fuel is seeping leaking out from the screws of the manifold and dripping down. It doesn't appear to be from the carbs. Any suggestions as to what it is and what to do?
1987 170 Striper
November 04, 2008, 12:42:35 AM
MarshMarlowe196
« Reply #1 on: November 04, 2008, 12:42:35 AM »
What year is the Mercury?  How does the motor run in it's present condition?
From my experience, Two-Stroke outboards are about the most inefficient engine ever designed (something like 10% of the total fuel you use to power it is actually being turned into energy).  A slow leak of fuel around the manifold is usually pretty normal on an older two-stroke outboard.  Not to school the wise, but the reed valve that opens and closes as your engine runs and pulls fuel into the carb, it doesn't shut perfectly, so you have unburned fuel that "seeps" out.
There's a possibility that you have a clog somewhere in the fuel delivery or maybe a dirty carb, but you would likely have a poor idling/running engine.
I'd say that if the engine runs well, I might get a second opinion, but I personally wouldn't worry about it.
Key West 1720 / Yam C90
Sold: 1973 Aquasport 19-6
November 04, 2008, 12:59:22 PM
jsakat1
« Reply #2 on: November 04, 2008, 12:59:22 PM »
It's a 93 90 HP Merc. The fuel loss looks little bit more than normal. I think the carbs are dirty as well from sitting, so I am going to clean them out.
1987 170 Striper
November 04, 2008, 12:59:45 PM
jsakat1
« Reply #3 on: November 04, 2008, 12:59:45 PM »
Thanks for the reply....
1987 170 Striper
November 04, 2008, 05:18:05 PM
MarshMarlowe196
« Reply #4 on: November 04, 2008, 05:18:05 PM »
Nothing wrong with cleaning a carb.  Only good things can come from it :)
I kind of miss the days when I knew what was wrong with my motor...  Maybe the new one will just never break... ha!
November 09, 2008, 09:57:22 PM
gw204
« Reply #5 on: November 09, 2008, 09:57:22 PM »
Could be ethanol related.  I just fired up my '82 Merc. 115 for the first time in about 4 years.  After about 30 minutes of idling, mine started leaking gas from the screws in the carb bowls.
Brian
St. Leonard, MD
1981 Mako 17
1986 Grady White 227
