I have a 22.2, so maybe this doesn't apply to your boat, but, the only time I've ever had my forward compartments fill is when the boat is on the trailer, with the tongue jacked up really high. The boat is designed to be self bailing when level, so elevating the nose doesn't buy you a whole lot. I know the trick about trying to drain bilge water by elevating the tongue, but for general storage, it's not the best thing to do. On my boat, the area where the hatch seals to the deck has channels that run back to the main deck. Would see if you have these channels and, make sure they're perfectly clean at all times. If they're not, it's easy to see how the water level in the lip area could rise and, fill the compartments. Before I made a path for rainwater to collect in the bilge, I would deepen these channels under the hatches.
