Aquasport Resources
Another easy courtesy light solution
Topic: Another easy courtesy light solution (Read 2401 times)
October 27, 2008, 10:48:42 AM
Read 2401 times
DOCREED
October 27, 2008, 10:48:42 AM »
If you like red courtesy lighting, simply buy sealed LED trailer side lights. they are inexpensive and completely sealed. Mount them under a gunnel or under the console and no one will know.
I did this years ago with my Bertram in Marblehead. Back then I used a perko deck mount stern light and just replaced the clear lens with a red one.
No one else had courtesy lighting back then.....maybe I started the craze?????????
naaa.... doubt it.
89 250 CCP
full transom
Twin Merc 150\'s......thirsty? YES they are.
October 29, 2008, 04:28:21 PM
compcrasher86
October 29, 2008, 04:28:21 PM »
courtesy lights are awesome, hands down. LED is the way to go because you often need a couple courtesy lights to light up the deck. I never thought of using trailer lights, thats pretty genius.
Stock 1973 222 Open Fisherman
"Floor it"
October 29, 2008, 06:22:38 PM
Mechanical Master
LEDs
October 29, 2008, 06:22:38 PM »
I still like the Lego lights!
October 30, 2008, 08:44:57 AM
MarshMarlowe196
October 30, 2008, 08:44:57 AM »
Is there an advantage to using red lights over "white" (clear) lights? I have some courtesy lights installed in my console, and with the lights on, the sonar & gps on, it makes it a little harder for my eyes to adjust to the darkness and I end up shutting everything off so I can see. Are red lights easier on the eyes?
Key West 1720 / Yam C90
Sold: 1973 Aquasport 19-6
October 30, 2008, 12:52:57 PM
October 30, 2008, 12:52:57 PM »
Red is less likely to hurt your night vision.
October 30, 2008, 01:07:37 PM
MarshMarlowe196
October 30, 2008, 01:07:37 PM »
Interesting...
November 02, 2008, 10:10:51 PM
compcrasher86
November 02, 2008, 10:10:51 PM »
yeah for console lighting and helm lighting... go red. For me, I usually only use my deck lights when I am having a party or anchored/moored or anything so my nightvision usually has time to recover before I go underway.
As for the lego lights, well its just a hands-down cost-effective solution. Unofrtunately LED trailer lights are like 20 buck each whereas I was able to get like 100 LEDs standalone (translates to around 33 lego lights) for $17
"Floor it"
April 04, 2009, 03:45:10 PM
DOCREED
Re: Another easy courtesy light solution
April 04, 2009, 03:45:10 PM »
Here is an example:
2 1/2" Oval Red LED Side Marker
Operates 9-16 volt DC systems
2 Superbrite LED configuration
100,000 service life
Sonically sealed lexan lens and housing
Draws .005 amps
Size 2.5 x .625 x 1.062
200-4400 $6.99
http://www.vehiclelight.com/2004400.html
89 250 CCP
full transom
April 04, 2009, 11:40:14 PM
April 04, 2009, 11:40:14 PM »
Good post Doc.
On my Aquasport I mounted the red trailer side marker LED's under my t-top as dome lights. I mounted one under the console so I can find something in the junk piled in there at night. I mounted a couple in the bilge so I can check down there without hunting a flashlight.
I bought several more to mount in my flats boat. Bilge, under the console, and under the poling platform for tying hooks at night without trashing my night vision.
Aquasport Resources
