Author Topic: Roll Over  (Read 1892 times)
October 12, 2008, 06:11:56 PM
Smknflms
Tab position
« Reply #15 on: October 12, 2008, 06:11:56 PM »
Might want to check your tab position all the way up. If you take a straightedge off bottom of transom, tabs should be 1/2" above straightedge for 9" chord tabs and 5/8" for 12" chord tabs.  If one was installed level with bottom edge of transom that might explain your roll issues.
http://www.bennetttrimtabs.com/trimtabinstallation.pdf
see figure 6
Later
\"No matter where you go, there you are.\"
October 13, 2008, 06:58:51 AM
« Reply #16 on: October 13, 2008, 06:58:51 AM »
Buckaroo Banzai fan, Smknflms :?:
Sorry for the thread steal :cry:
October 13, 2008, 10:05:40 AM
skiph98
« Reply #17 on: October 13, 2008, 10:05:40 AM »
I'll check the trim tab measurement, but the reason the trim tabs were installed in the first place was to correct the rollover, the rollover didn't come with the trim tabs, in fact it doesn't roll with the tabs in play.
October 13, 2008, 10:07:02 AM
skiph98
« Reply #18 on: October 13, 2008, 10:07:02 AM »
Capt. Bob, not sure WHAT your post is about, but thanks anyway.
October 13, 2008, 01:31:48 PM
« Reply #19 on: October 13, 2008, 01:31:48 PM »
Quote from: "skiph98"
It has nothing to do with your port list, hence the apology.
It focuses on Smknflms signature line though I can't be sure that's what he's thinking.
October 13, 2008, 02:33:54 PM
skiph98
« Reply #20 on: October 13, 2008, 02:33:54 PM »
Gotcha, no prob.
Thanks,
October 14, 2008, 08:14:46 PM
« Reply #21 on: October 14, 2008, 08:14:46 PM »
Skip,
The gray insert is on it's way.
October 14, 2008, 11:30:46 PM
skiph98
« Reply #22 on: October 14, 2008, 11:30:46 PM »
thanks, I sent you an e-mail with info in it.
Skiph98
October 17, 2008, 04:06:43 PM
Smknflms
« Reply #23 on: October 17, 2008, 04:06:43 PM »
Line from Jerediah the eccentric pilot in "Mad Max Beyond the Thunderdome"
Thought it was kinda descriptive of a lazy day navigation with no where in particular to go or be.
Later
October 19, 2008, 12:14:40 AM
skiph98
« Reply #24 on: October 19, 2008, 12:14:40 AM »
Huh ?
