Hey Seabob,Today i changed my lower unit oil. The oil did come out slightly grey which means water in the oil. When taking off the 2 screws to change the oil, I noticed that the top screw had 2 teflon washers on it while the bottom screw did not have any. Is this normal? I would think that it isn't. Then, when i went to install the screw from the oil pump into the bottom opening, it would not fit, like it was too small and loose. I tried to install it into the upper opening and it fit fine. I then tried both screws in each opening and they worked fine in both. That was weird that i couldn't get the fitting to screw into the bottom opening. So I filled it from the top and slowly opened it to bleed out the air while I was filling it. Would you know why it did not fit into the bottom, strange. I will watch the oil and check it after a few times to see if the oil is changing color again, hopefully it was the missing washer that caused the water to get in.Not to ask again, but when you can, could you tell me where I could get that replacement cover hatch for my cabin entrance. SteveWhat kind of gas (size) lever should I use for the cover.Thanks Seabob
Hey BobI started a post if you could please advise that would be great. 98 Ospey 245. Thank you
Thanks for the picture. When I went to the photobucket link, only half the page showed. Thanks again. Steve
