Aquasport Discussion
Ex-Aquasport/Wellcraft employee (Bob C)...
8
9
10
31
Topic: Ex-Aquasport/Wellcraft employee (Bob C)... (Read 30983 times)
May 06, 2009, 01:17:38 PM
Reply #105
Re: Ex-Aquasport/Wellcraft employee
Reply #105 on:
May 06, 2009, 01:17:38 PM »
My Explorer has a tank hatch between the seats, about 140 gals long - no cutting, just unscrew and open (sounds easy anyway
May 25, 2009, 02:02:58 PM
Reply #106
Irish Rover
Reply #106 on:
May 25, 2009, 02:02:58 PM »
Seabob hope you can help me out. I have a 245 1999 Explorer and in the transome where the batteries are mounted the platform that they are mounted on seems to be sagging a little and I was wondering what that platform is made out of.
Thanks,
Judd Hogan
June 11, 2009, 03:34:13 PM
Reply #107
turbor2
Reply #107 on:
June 11, 2009, 03:34:13 PM »
I cut mine out last year to do some other repairs. It was 1/2 inch plywood with a layer of fiberglass over it. Mine was in good shape so I reglassed it in.
June 11, 2009, 08:25:33 PM
Reply #108
Irish Rover
Reply #108 on:
June 11, 2009, 08:25:33 PM »
Thanks for the info. I wasn't sure if the weight on the batteries was to much. Nice to know the plywood had fiberglass around it.
thanks
Judd
June 27, 2009, 08:11:10 AM
Reply #109
cc150a
Reply #109 on:
June 27, 2009, 08:11:10 AM »
Seabob,
I realize you didnt work there in 2002, but are there ant issues you know of that i should be concerned with with my 2002 200 osprey. I bought the boat used and noticed someone re-sealed the fish box pump out fitting.
Bob
"2002 Osprey 200"
June 28, 2009, 06:56:27 PM
Reply #110
Rigging Master
Reply #110 on:
June 28, 2009, 06:56:27 PM »
Bob,
By "re-sealing" the pump-out fitting, do you mean that "someone" simply applied a new bead of caulk around the fitting? It may have just been a simple leak that the new bead fixed.
The 200 Osprey has been around a long time, pretty much all the bugs were worked out of her by the time I got there in '94. But leaks do develop over time, so that may explain the additional sealant. The boat is excellent with a 150, which I assume is what you have, she'd be really nice re-powered with a Suzuki 175 4S.
June 30, 2009, 10:23:09 PM
Reply #111
cc150a
Reply #111 on:
June 30, 2009, 10:23:09 PM »
Seabob,
No they didnt just put a new bead a caulk, its more like globs of caulk all around the fitting. I should probably remove all that caulking and do a better job. Other than that the boat is beautiful. It looks new! It doesnt appear to be holding any water under the deck and the main bilge is always bone dry. I have a 115 Yamaha which a appears to be plenty of power and it runs amazing. This is my first Aquasport. Ive owned Parker, Chriscraft, Boston Whaler etc. and this boat rides as good as any of them.
"2002 Osprey 200"
July 01, 2009, 08:32:36 AM
Reply #112
MikeR
Reply #112 on:
July 01, 2009, 08:32:36 AM »
Seabob,
I have one of those boats you may have built! I have a '97 21.5 DC. I absolutely love the boat. I've had it for about 8 years now and it has been a great boat. I've had a 200HP Johnson on it since I bought it. The motor had some "mechanic induced problems" (long story)and I decided to repower with a Yamaha F225. I'm going to be mounting the motor in the next few days and was wondering if you had any advice on where to mount motor. Should I just use the same holes I used on the Johnson? Let me know your thoughts. I may have some more questions if I get in a pickle with the install!
PS - I have a vacation house Weeki Wachee so I'm just down the road from you (at least on the weekends!)
Thanks for all your input! I've already learned a lot from your responses...
MikeR
July 01, 2009, 09:44:31 AM
Reply #113
Rigging Master
Reply #113 on:
July 01, 2009, 09:44:31 AM »
Mike,
Use the same holes as the bolt pattern on those motors is a standard BIA mounting pattern. I would start with the same height, i.e. 2nd hole down, third hole down, whatever. The key is to get the cav plate about level with the keel when the motor is at neutral trim. Make sure your new Yammi is the same shaft length as the Johnson (should be a 25" shaft). The additional 25 horse should make her a better performer, although some of that could be offset by the heavier 4S. Check your prop size as well. Gear ratio can have a lot to do with prop selection, assuming the Yammi and Johnson can spin the same diameter props.
I loved the 215 DC. Nice angular lines, plenty of room in the cockpit, the availability of a freshwater sink forward of the passenger seat, just a great boat all-around. Where are you based at?
July 01, 2009, 04:05:56 PM
Reply #114
MikeR
Reply #114 on:
July 01, 2009, 04:05:56 PM »
I live in Apopka but try to get over to Weeki Wachee as often as I can. Thanks for the advise. Nice to get confirmation on where to mount it...
July 01, 2009, 04:32:07 PM
Reply #115
Rigging Master
Reply #115 on:
July 01, 2009, 04:32:07 PM »
Mike,
Lived in O-town for 14 years, had my house built in Ocoee, just west of Apopka-Vineland off of A.D. Mims Rd. Inlaws (former) were all Eustis/Tavares/Leesburg/Umatilla residents. And many a Zellwood corn festival was attended!
Just keep in mind the guidelines I spoke of. Any competant dealer can get your Yammi set up right. Any other questions, feel free.
Bob
July 01, 2009, 04:54:22 PM
Reply #116
MikeR
Reply #116 on:
July 01, 2009, 04:54:22 PM »
That's funny... I grew up in Eustis!
July 01, 2009, 06:56:10 PM
Reply #117
Rigging Master
Reply #117 on:
July 01, 2009, 06:56:10 PM »
Mike,
King's Taste BBQ? Remember, or is it still there?
Bob
July 09, 2009, 09:22:03 AM
Reply #118
MikeR
Reply #118 on:
July 09, 2009, 09:22:03 AM »
Of course! Love Kings!
July 09, 2009, 12:43:22 PM
Reply #119
wespants
Reply #119 on:
July 09, 2009, 12:43:22 PM »
Seabob,
Was told that you may be able to provide some insight to the 175, although it wasn't one of the boats you built. I'm planning to shop for a 170 or 175 this fall - they each seem to have some of their own merits so I'm trying to decide between the two (you may have seen my recent post). As far as the 175 made during your time at Aquasport, does it have any wood? If so where? Do you know of any things to watch out for on these?
I used to have a '97 215 Explorer; I'm sure you are more familiar wtih that boat. I thought it was a great boat with good quality, so a 175 of that vintage seems like a good choice.
Thanks for being such a great resource to everyone!
8
9
10
31
