Author Topic: Help with prop  (Read 1102 times)
September 25, 2008, 03:33:54 PM
Read 1102 times
davis74
Help with prop
« on: September 25, 2008, 03:33:54 PM »
Looking for help choosing a prop for my 1971 19-1 that I just purchased. It has a 115 yamaha 2 stroke. The prop that is on there now is a 13x19 aluminum. The motor is turning over 6000 rpm according to the aftermarket dial style tach ( not yamaha digital) Not sure if I need more pitch or a new tach. Any thoughts
September 26, 2008, 09:53:48 PM
« Reply #1 on: September 26, 2008, 09:53:48 PM »
You need some confidence in your tach somehow before you start changing props.
September 27, 2008, 09:01:04 AM
Tach
« Reply #2 on: September 27, 2008, 09:01:04 AM »
Are you doing 50 MPH?  That would be about the speed for over 6000 RPM with a 19 pitch prop...   Check your tach settings and make sure they are set correctly - not all tachs work with all motors.
October 16, 2008, 11:23:54 AM
MarshMarlowe196
« Reply #3 on: October 16, 2008, 11:23:54 AM »
Hmmm... I just put a new Suzuki  140hp on my 19-6 Aquasport.  What is a 19-1?  Is that the same boat?  I think you'd be hard pressed getting a 19-6 to do more than around 40mph given the hull design w/o hanging at least a 200hp outboard.
When I first got my motor, it had a 19" pitch and would scream at over 6000RPMs to break 40mph.  Well, blessing in disguise, I chewed up the 19" prop pretty good at a boat ramp, and had a 21" prop laying around and switched to that one (out of necessity...).  Now I can cruise at 30mph doing a little over 4000rpms and about 42-43mph @ 5800rpms.  I think the 21" is perfect for the boat, but a 20.5 or 20 would work well, I suspect
Key West 1720 / Yam C90
Sold: 1973 Aquasport 19-6
October 16, 2008, 03:55:17 PM
davis74
« Reply #4 on: October 16, 2008, 03:55:17 PM »
Thanks for the help. I think a 21 will be right for me also. I am running a 19 and going over 6000. I'm having problems with the GPS that came with the boat so I have not been able to get a speed. The 19-1 was only built until 1972 (i think). Here are a few pics from the night I brought her home. One more question I dont seem to be getting much bow rise when I trim the motor up. I feel the boat would ride better with the bow a little higher. Most of the boats I drive are larger but the bow seems to rise more on those when I trim the engines up. Could it be because of the flat bottom that engine trim does not affect it so much or just because the boat is small?
October 16, 2008, 05:19:11 PM
Lift and trim
« Reply #5 on: October 16, 2008, 05:19:11 PM »
Some boats are more sensitive to trim than others.  It has to do with the length versus width of wetted surface.  A boat with a wide and short wetted area will be much more sensitive to trim than one with a long, narrow wetted area.  I think your (and most) Aquasport has the latter - a fairly long and narrow wetted area at plane than some other boats.  That will mean that the bow rises less with "out" trim than a boat with a wide, short wetted area.
Another contributing factor is the "depth" of the prop compared to the surface.  Think of the prop as a lever - the longer the lever - the more effect.  A prop 24" under the surface will have a bigger lever effect than one 12" under the surface.  Your boat has a semi-V hull, and if the motor is mounted right, the prop is only about 16" or so below the surface.  Not much lever there, and trim is less effective than on a deep-V boat with a prop that is 25" below the surface.  Of course, that other boat can't get into skinny water like your boat, either!
Hope this helps - see ya on the water!
October 16, 2008, 07:05:29 PM
davis74
« Reply #6 on: October 16, 2008, 07:05:29 PM »
Thanks for the info that makes sense. Badonquasport196  is the 21 pitch stainless or aluminum?
October 21, 2008, 05:05:28 PM
MarshMarlowe196
« Reply #7 on: October 21, 2008, 05:05:28 PM »
Stainless.  Anyone want a chewed up 19" pitch prop that fits a suzuki/johnson?  Its repairable... come on... :)
