Aquasport Discussion
What do you think about this 19'6 ?
Topic: What do you think about this 19'6 ? (Read 809 times)
September 09, 2008, 07:48:16 PM
Read 809 times
ANTIBLING
September 09, 2008, 07:48:16 PM »
I am considering dropping my 87' 17 striper and buying this 80% already finished 72' 19'6. The stringers have already been replaced and filled with foam and the floor is already glassed in with the exception of one rear panel above the bilge. Transom is solid, which is hard for me to beleive because of it being original. No signs of stress, no flex at all with that 125 merc with the jackplate. Also has a new aluminum gas tank. Heres a few pics, give me any ideas, thoughts, tips..?
87\' 170 striper
September 09, 2008, 08:20:28 PM
sean
September 09, 2008, 08:20:28 PM »
thats not pretty, still needs work but I have a 196 I only bought 4 days a
go and went out just after Hanna hit and she rides nice in 2 to 4 footers with a 20 mph wind a little wet but rode great very nice ride this is my 6 th boat, and I think it rides better then my 20 mako.
September 09, 2008, 08:27:06 PM
Mechanical Master
19-6
September 09, 2008, 08:27:06 PM »
I would look carefully at the transom - don't like what looks like seepage coming out on one corner...
Boat still needs a good deal of work, but could be a diamond in the rough. You gotta wonder what they used a pick-ax for in the rebuild!
Good luck and see ya on the water!
September 09, 2008, 09:12:49 PM
ANTIBLING
September 09, 2008, 09:12:49 PM »
I really don't think too much work is needed, most the guts are done. I want to finish the inside then use it until the winter time when ill strip the bottom paint and paint the hull/topsides. Once the last panel is glassed in, wouldnt I just have to feather everything smooth, bondo it all smooth, then paint? I dont think it will be too bad, if I even end up buying it... I have a 2004 115 yamaha that I wanted to put on it, but I think that may be a little underpowered
87\' 170 striper
September 09, 2008, 10:08:36 PM
Marcq
September 09, 2008, 10:08:36 PM »
Well, looking at the pictures, for me that looks like a botch job, wouldn't be surprised he did the same kind of work under the deck and looks like there's no more access to the fuel tank. The hull looks alright , the transom, hard to say
Keep your Striper and fix her up damn it
Marc..
September 10, 2008, 04:49:39 PM
compcrasher86
September 10, 2008, 04:49:39 PM »
I dont beleive a 115 Yamaha would be underpowering it. Now 90, that would be underpowering it. I have a 22-2 and it has a 140 and I think it goes at breakneck speeds.
Stock 1973 222 Open Fisherman
"Floor it"
