Author Topic: Info on 81 20' Walk Around  (Read 601 times)
August 26, 2008, 08:09:24 PM
Read 601 times
davis74
« on: August 26, 2008, 08:09:24 PM »
I was considering buying an 81 20' WAC but have not been able to find much information on this model. I was hoping I could get some feedback on this boat from anyone who has owned one. The boat has a 150 Suzuki. Thanks for your help.
August 27, 2008, 05:06:07 AM
« Reply #1 on: August 27, 2008, 05:06:07 AM »
Welcome aboard Davis  :!:  :!:
Is this the model you're looking at buying?  Try looking in our photo gallery on the first page toward the bottom for all the literature we have so far.
August 27, 2008, 10:10:09 AM
davis74
« Reply #2 on: August 27, 2008, 10:10:09 AM »
Yes that is the model. How is the ride on that model? Are there any problems I should be aware of? Is 150 hp enough for this boat? Thanks again for your help.
August 27, 2008, 11:05:07 AM
jdupree
« Reply #3 on: August 27, 2008, 11:05:07 AM »
Davis,
I have a 1981 200 CCP which is basically the same hull as the 20' WAC.  The ride is great for a 20' boat.  I have a 200HP Mercury on mine.  I would think a 150HP might be a little underpowered but I guess it depends on prop and load.
As far as known problems, I don't know of any.  I would just look for normal things such as soft spots in deck, make sure the transom is good.  I would go ahead and plan on a new fuel tank if the original is still in there.  Who knows it might still be good but it has bound to have corrosion under the straps by now.
Hope this helps :!:
John L. Dupree, III
AQABLA84E999
Member #257
