Author Topic: Color Codes for most ignition switches and wires  (Read 1913 times)
August 18, 2008, 06:18:25 PM
Read 1913 times
compcrasher86
« on: August 18, 2008, 06:18:25 PM »
Hey everyone I found an awesome website documenting the wiring for most brand name engines.
If you have a OMC/BRP engine (Evinrude, Johnson), go here:
http://continuouswave.com/whaler/refere ... e.html#OMC
OMC/BRP people also get an awesome page with explanations and diagrams:
http://continuouswave.com/whaler/reference/ignitionSwitch.html]
For Mercury engines, go here:
http://continuouswave.com/whaler/refere ... .html#Merc
For Yamaha engines, go here:
http://continuouswave.com/whaler/refere ... e.html#Yam
For Hondas, go here:
http://continuouswave.com/whaler/refere ... e.html#Hon
Stock 1973 222 Open Fisherman
"Floor it"
June 20, 2011, 09:36:53 PM
Possible Resource Link
« Reply #1 on: June 20, 2011, 09:36:53 PM »
Mod Edit:  21 June 2011:
Update of the above link. Be sure to check each one that pertains to your motor.
to Marc aka "Flounderpounder 225
Came across this while looking for tach wiring on this Mercury I am working on.
June 21, 2011, 10:35:49 PM
seagate
Re: Color Codes for most ignition switches and wires
« Reply #2 on: June 21, 2011, 10:35:49 PM »
I can't believe you posted this just when I needed it most.One question does the OMC wiring match the Johnson 140 4 stroke motor seeing it is a Suzuki motor in a Johnson suit I'm trying to finish installing this motor.
Thank you SO much.
June 22, 2011, 07:17:01 AM
« Reply #3 on: June 22, 2011, 07:17:01 AM »
Quote from: "seagate"
The original article carries a 1999-2000 year copyright. Additions appear to be circa 2006 and was first posted (I'll assume) on this Forum in 2008.
Latest update appears to be May 2011 and there are no Suzuki references but plenty of disclaimers as to accuracy. It therefore first, should be taken as a guideline rather than gospel. Should help with troubleshooting and feel free to document, support and post any discrepancy you may find.
Thank you and good luck.
June 22, 2011, 09:25:09 AM
seagate
« Reply #4 on: June 22, 2011, 09:25:09 AM »
Thank you I have a service manual coming But yours sure helps with the old wiring.
June 24, 2011, 11:21:48 PM
seagate
« Reply #5 on: June 24, 2011, 11:21:48 PM »
I went and got a new Key set up today that cut the guess work to O.I had to cut and crimp for the neutral safety switch and the trim and tilt on the old controls but that was better than having to but a hole new control.Got everything ready to sea trial maybe tomarrow.
Thanks again for all the help.
