Author Topic: 1974 19-6 Redo the deck soon  (Read 724 times)
August 11, 2008, 04:51:57 PM
Read 724 times
luv2flycessna
    • http://s364.photobucket.com/albums/oo90/luv2flycessna/
« on: August 11, 2008, 04:51:57 PM »
Just wondering if anyone has looked into using Polycarbonate panels for the decking on an Aquasport? My deck is getting a few soft spots and was looking at the polycarbonate panels at Home Depot. Looking at that for keeping the weight down. Any input would be great good or bad. Or should i just go back with plywood?  :roll:
luv2driveaquasport
\'74 19-6 \'86 Mercury BlackMax 150HP
August 11, 2008, 08:44:41 PM
« Reply #1 on: August 11, 2008, 08:44:41 PM »
Do not know anything about polycarbonate, but there are several composite options you can pursue that are meant for fiberglass sandwich construction - first on my list would be nidacore.  It is light, and fairly easy to work with.
August 11, 2008, 10:03:53 PM
slippery73
« Reply #2 on: August 11, 2008, 10:03:53 PM »
You will have adhesion problems with the poly. Only problem I see with the plastics. The nida-core is what I'm using, very easy to use and cheap for composite.
