Author Topic: New member/owner introduction  (Read 478 times)
August 11, 2008, 11:31:21 AM
Read 478 times
Ken G
« on: August 11, 2008, 11:31:21 AM »
I stumbled across this site several months ago and have been reading it regularly since then.  I finally registered last week to post a smart ass comment about a boat description on ebay where someone stated that their model Aquasport had the motor in the back of the boat.  I thought that was unique.
Anyway,  I've been searching for a used CC knowing that I didn't have the cash in hand until I sell a dump truck that I own but don't use anymore.  I've been looking at Aquasports, Wellcrafts, and older Mako's in the 17' to 21' range.  I usually fish the Ohio River for catfish, Lake Cumberland for stripers, and I kayak fish in Florida with one eye pointed toward the bays and Gulf.
While searching Craigslist on Friday I stumbled across this add for an AS 19-6:  http://detroit.craigslist.org/boa/785813206.html   The pictures are just blurry enough to hide any problems so I made the 4 hr drive to check it out.  For $725 I now own a 1977  Aquasport 19-6 project hole in the water that I can throw money into.
For being 31 years old the hull is in decent shape.  The floors are solid and  the transom feels the same.  I plan on drilling some test holes in the transom to check it out before hanging a motor on the back.  When the dealer took it in the boat had a 40 hp tiller and a smaller tiller motor hanging on the transom.  They actually bought it for the motors.  The boat must have been owned by an older man that trolled the Detroit River and Lake Erie he didn't go anywhere fast.  I guess the top cap got chalky so he painted it with a brush.  He also refinished the teak gunwale caps with a couple of coats of brown paint for that 'classy' look.
Yesterday I peeled back some brown gunk around the fuel tank access panel and removed the panel.  I found the tank area completely foamed, and full of water.  I could also smell fumes which I hoped were due to the  hoses being in pretty sad shape.  After digging out the foam, the tank looked pretty good until I hoisted it out with an engine lift.  I found 2 holes in the top which began leaking out the 40 or 50 gallons of water/gas mix which was in the tank.  I now get to make a donation to the local hazardous waste recycling center and search for a new tank.  The fun begins.
Sorry for being long winded on my first post.  While I search for an outboard and other incidentals what is the going price for a new 50 gallon aluminum gas tank?
August 11, 2008, 12:13:48 PM
Mad Dog
« Reply #1 on: August 11, 2008, 12:13:48 PM »
Welcome aboard :!:  You just discovered one of the most common problems with the older Aquasports (and any other make with aluminum belly tanks).  There are a couple of recent threads in the Rebuild forum on tank replacements.  I recommend you go there first.
What you said is true, "a boat is a hole in the water surrounded by wood/glass into which one purs money."  But, if you do things right you'll a lot of years out your AS.
Suggestion:  Another test for the transom is to remove some of the hardware; lifting eyes, engine mount bolts, etc.  If those come out wet then do a little digging.  Use a small flat blade screw driver and probe at the wood core.  If you get more soft wood out you may have a problem.  Try drilling holes then to see how far the moisture has reached.  If the hardware is dry then may have lucked out.
Good luck!  Post some pics.
MD  :wink:
