Author Topic: Gunnel and transom rod holder question  (Read 702 times)
July 12, 2008, 11:48:18 AM
Read 702 times
waterdoc
« on: July 12, 2008, 11:48:18 AM »
Can anyone explain to me the rationale behind using the various "degrees" of rod holders and where they are supposed to be placed. I've seen 0 degree, 15 degree and 30 degree holders but don't know where they are meant to be used. I'd like to place several in the gunnels and two in the transom cap.
Thanks.
Pics of the boat to come shortly as the tower and rigging are now underway.
July 12, 2008, 12:23:44 PM
Rod holders
« Reply #1 on: July 12, 2008, 12:23:44 PM »
You often want different angles if you are using outriggers.  The rod to the outrigger is more upward than the line that goes straight off the back of the boat.  This helps with line management and prevents tangles.
If you are using a rod holder for use with an outrigger tube, you need a 45.  Normal is a 30, and 15 is used for the rod to the outrigger.  Also consider not running all of them straight back - angle some out a bit, particularly the 15 to the outrigger.
So from the back up, you would have a 30 in the rear, a 15 (or 30 if you prefer and don't use outriggers) at mid-point angled outboard a bit (whatever the gunnel will handle), and a 45 above that (almost in line with the console).  I put an extra 30 in between the front and the 2nd because it's easy to get to when trolling.  My front one is actually an 45 outrigger base, but can be used as a rod holder.
Check out the diagram below to get the idea:
July 12, 2008, 02:37:25 PM
waterdoc
rod holders
« Reply #2 on: July 12, 2008, 02:37:25 PM »
Thanks very much for the info....definitely helpful.
