Author Topic: Fuel Tank Epoxy Prep  (Read 948 times)
July 01, 2008, 07:56:26 PM
Read 948 times
Wayne'sWorld
« on: July 01, 2008, 07:56:26 PM »
I had my fuel tank repaired (see before photos under '85 CCP refresh) and I'm ready to coat with coal tar.  I've read some of the topics on replacing fuel tank but haven't seen the step-by-step process for coating the tank.  The top of the tank was severely pitted, but sides and bottom were good.  I took the tank to a local shop and they cut off the top and replaced with a sheet of 5052 Aluminum .125".  I read the instructions on the can of coal tar epoxy (Rust-Oleum brand from Grainger).  I'm thinking the media blasting they recommend is to rough the surface for better adhesion.  Since this process is not readily available to me, I slapped a 40 grit sanding disk onto the orbital sander and went to work.  Here are the results:
How does this look?  Do you think I'm on the right track?
Now, what specific product do I use to wipe the tank clean just before applying the coal tar?  I'm intending to roll it on with a 3" roller, wait a few hours and then hit it with a second coat.  Please comment and thanks for helping me along! :)
July 02, 2008, 10:23:46 AM
Mad Dog
« Reply #1 on: July 02, 2008, 10:23:46 AM »
The surface looks ready for application.  That 40 grit is more than enough.  I would wipe the surface down with liberal amounts of acetone to remove any oils or solvents.  If you want to be extra sure, wash the tank with soap & water to get all the loose particles off then wipe with the acetone.  White vinager is a good & safe solvent for the wash down.
MD  :wink:
July 02, 2008, 10:48:21 PM
Wayne'sWorld
« Reply #2 on: July 02, 2008, 10:48:21 PM »
Thanks for the reply, MD.  I've been kicking around some ideas on how I can coat the entire tank at one time.  Two coats of course.  This means no sawhorses.  Maybe I'll toss a rope over a strong tree limb and hang the tank then apply the CTE. :shock:
July 08, 2008, 08:43:54 PM
Carvguy
« Reply #3 on: July 08, 2008, 08:43:54 PM »
I,m getting ready to do the exact same thing. You could take a picture of our tanks and you couldn't tell them apart.I'm going to wash mine with white vinager and role or brush on still looking into the best option.
July 09, 2008, 11:35:23 AM
Mad Dog
« Reply #4 on: July 09, 2008, 11:35:23 AM »
Quote from: "Wayne'sWorld"
Sure if you suspend it using the fill tube or a C clamp through the sending unit port.  Those tanks don't weigh that much so you could even use a swing set if you have one.
If you have not seen this before take a look at this link.  It gives detailed instructions, explainations & precautions for installing aliminum tanks.
http://marinesurvey.com/yacht/fueltank.htm
This is a link where you can find the rubber mounting strips mentioned in the article above.
http://boatbuildercentral.com/proddetai ... 9443_1%2F4
MD  :wink:
July 17, 2008, 09:47:05 PM
Wayne'sWorld
« Reply #5 on: July 17, 2008, 09:47:05 PM »
This was my recipe for applying the coal tar epoxy.
Ingredients:  1 qt distilled vinegar, 3 qt water, thick wooden paint stirrer (for 5 gallon paint bucket) so it won't break, 15" length of wire coat hanger, cordless drill, standard paint roller pan, 4 plastic shopping bags, 2 2" throw away paint brushes, 7" paint roller, 2 7" roller covers, two old beach buckets stolen from the kids.
Note:  A gallon of CTE will easily coat two 85 gallon tanks.  I should have posted to the site to see if anyone else in the area is doing the same thing at the same time and we could have split the cost!
Been on vacation for a week so I couldn't post to Carvguy.  I got my CTE in the mail cost 74.50 delivered.  Mix vinegar and water and wash tank well. Towel dry well and set it up on sawhorses.  My tank has four 3" x 6" "feet" welded to each corner of the bottom of the tank that serve as standoffs.
The coal tar was very thick with a thin coat of liquid on top.  Using a thick wooden paint stirrer, mix coal tar pulling the substance off the bottom of the can especially getting into the corners.  Shape coat hanger into a z shape and chuck tight into drill.  Using the drill, mix the hell out of the coal tar till it looks like smooth chocolate icing and thinned out considerably.
Put the paint roller pan into a plastic bag and tie off.  When you pour the CTE into the paint pan, the plastic bag protects the pan from getting CTE all over it.
Glop out a quart of the coal tar into the beach bucket.  While mixing at slow speed with the drill, slowly pour 1/4 of the activator into the coal tar.  Continue mixing for a few more minutes.
Coat the bottom of the tank first (not the standoffs) using roller.  Lay it on like thick paint so it has a significant orange peel look.  Instructions say that final coat should result in 2 -4 mil thickness.  Flip tank and coat sides and ends.  Using brush, finish the vent tube, fuel inlet and outlet fixtures (did not coat where in and out lines fit on fixtures) and all in between where the roller won't fit.  Be careful not to get the CTE on any threaded parts.  Roll out the remainder of the top of the tank.  Let dry 6 hours, maybe more in humid weather.
Repeat above to apply second coat.  Let dry 24 hours or more.
Special Notes:  to clean up roller pan, let CTE harden some then simply pull pan out of the bag, turn bag inside out, no mess.  To remove roller cover from roller, place roller into plastic bag, grasp bag around roller cover and slide cover off roller, no mess.  Toss brushes into the same bag.  To clean beach buckets... don't, take the kids to the dollar store and treat them to some new ones.  Buy a bag of water ballons while you're there and have some fun with the kids while the CTE dries.
Disclaimer:  I hold no special skills or knowledge of this process.  This is my first experience with applying CTE.  This post is for informative purposes only.  If anyone's process differs, please add on for the benefit of all members.  If I have proceeded down a wrong path during any stage of this process, rip into it to make corrections.  I won't be offended and we all learn!  Pro's would probably do it differently.  This is the shade tree mechanic way of doing it while the ribs are cookin on the grill!
