I'm in need of some advise. Recently purchased a 1992 23' aquasport Explorer W/A. The transom flexes a litle more than it should & it is bowed out a little where the OB mounts. I don't believe it is serious enough for replacement. What i have seen on a similar boat is a thick aluminum reinforcemment plate underneath the OB mount that wraps over the transom cap down on the fwd side. The OB then bolts thru both surfaces of the plate. the plate was approx 3' wide & 1/4" thick. This seemed to work quite well extending the life of the transom. Has anyone seen this before or have any other ideas?
