Author Topic: Any Evinrude experts out there?  (Read 766 times)
June 07, 2008, 10:10:37 AM
Read 766 times
« on: June 07, 2008, 10:10:37 AM »
Well I posted to the various Johnson/'rude Forums and got little response so I thought I'd dance with who brung me  :shock:
96 200 V6. I'm fouling the lower right side (#6 I think) plug. The other five are perfect. I re-built the carbs last year and they seem to be working ok.
I can tell I'm dragging a cylinder while underway (sound, rpm fuel consump.) and it now backfires through the exhaust when I run it on the muffs. This is followed by a cloud of white smoke.
I know, it could be several things. I can clean the plug, hold it against the block and crank. I see a strong spark. Put it all back together and it fouls the plug.
ANY suggestions are greatly appreciated and as usual,
Thanks in advance.
June 08, 2008, 07:11:29 AM
« Reply #1 on: June 08, 2008, 07:11:29 AM »
Did you try posting the question here?  This guy is normally pretty quick and has helped us before. http://www.themarinedoctor.com/cgi-bin/YaBB.pl
June 08, 2008, 07:30:11 AM
« Reply #2 on: June 08, 2008, 07:30:11 AM »
Quote from: "RickK"
Thanks Rick, I had not tried there.
I'll sign up and post.
Thanks again.
