Author Topic: Other than GL-5 rating does anyone prefer a better gear oil?  (Read 556 times)
June 05, 2008, 11:23:45 AM
Read 556 times
gcapehart
Here we have Marine Pennzoil, obvious Johnson, Quicksilver, Lubrimatic etc; which all have the GL-5 rating. But when you look at gear oils as 80-90w etc; and you see synthetic blends from Valvolene, Mobil 1 full synthetic, and Lucas they all have the GL-5 rating too and also say they are "Grrrrrrrrreat" for outboards like Frosted Flakes. Seriously has anyone tried them with any better effects? Or is it better to use standard and just change it more often? Gary
Maine25XF. Late to the gate we love our boat. Others are humbled by the Sally-Carol. We treat her like family, only better! If you have any tips, insights, or positions on the health benefits of two-stroke exhaust,  please opine and inform. Gary
June 05, 2008, 05:25:31 PM
Oils
« Reply #1 on: June 05, 2008, 05:25:31 PM »
I've never seen a lower unit failure due to oil.  From my experience, here's what kills lower units/gears:
1.  Water intrusion - especially in areas with freezing temps in the winter.
2.  BIG BUMPS - hitting something hard (reef, rock, submarine, etc.)
3.  Fishing line/net - destroys the seals; see #1 above
4.  Leaks - oil leaks out, even if water does not leak back in (see #1 above), gears go dry and fail.
5.  Misadjusted or incorrect shifting settings that prevent full engagement in forward (or reverse) - causes bearing, cone, or gear failure.
So use whatever you like or trust - change it out 1-2 times a year - but check what comes out carefully for water or contamination!  If you see ANY water, find the leak and fix it.
Look at the fill and bleed holes before you remove them for leakage - if you see any, replace the seal or o-ring on the plug.
Hope this helps - see ya on the water!
