165/170/175 Rebuilds
Foam in the 170?
Topic: Foam in the 170? (Read 938 times)
May 19, 2008, 01:36:02 PM
Read 938 times
Marcq
Foam in the 170?
May 19, 2008, 01:36:02 PM »
Just wondering, is there foam just inside the stringer in my boat ?
Marc..
May 19, 2008, 08:43:49 PM
scyharris
May 19, 2008, 08:43:49 PM »
When I had the innerliner tore out to replace the transom in my 1984 17', the only place that was foamed were the inside of the stringers and a little between the hull and liner. The rest is absolutely wide open! Hope that helps.
May 20, 2008, 02:02:29 AM
Marcq
May 20, 2008, 02:02:29 AM »
Thanks, wasn't sure if there was some on each side of the stringers
Marc..
May 21, 2008, 08:59:42 AM
MJB
May 21, 2008, 08:59:42 AM »
My 1976 170 had foam on the inside of the stringers and on the outside of the stringers between the stringer and outer hull the entire length of the boat. Not sure about the 1979 model year.
Mike
AB, NC
1976 Aquasport 170
1988 MAKO 285
Foam in the 170?
