Author Topic: How to remove paint on the deck  (Read 819 times)
May 08, 2008, 05:59:49 PM
Read 819 times
James Derz
« on: May 08, 2008, 05:59:49 PM »
What is the best way to remove paint on non-skid decking.  The previous owner painted some light-blue paint on the deck. It is not very thick and even worn off in some areas.  SO...sand it off?  Paint over it? Use some type of paint remover?  Again..not a thick application, I tried to post pix several times to no avail...sorry and thanks!
James
1970 22-2 FB
May 08, 2008, 11:23:45 PM
Mad Dog
« Reply #1 on: May 08, 2008, 11:23:45 PM »
Is this the original factory non-skid sole?  If so, sanding the paint off means removing the fiberglass.  Using a paint remover is not a good idea.  I tried some on a console which softened the skin.   :!: Maybe a pressure washer with a turbo head would do the trick  :!:   You said the paint is thin. That tells me there was no primer used so the bond is probably weak.  That way you remove the paint but keep the texture.  If you repaint be sure to prime.
May 09, 2008, 08:22:27 AM
Paint removal
« Reply #2 on: May 09, 2008, 08:22:27 AM »
Try a wire brush.  It will remove the paint from the crevices and even enhance the non-slip surface a bit.  You can use a hand-held or a circular one in a drill.
Good luck!
May 09, 2008, 09:55:52 AM
James Derz
paint
« Reply #3 on: May 09, 2008, 09:55:52 AM »
It is not the original paint because I removed the bench seat and under the seat is the original white non-skid.  They definetly did not prime, it's alomost like if you white washed a fence.  The color is there but very thin and lightly coated.  The pressure washing sounds like a good idea, I think I am going to try and use a palm sander with lo-grain paper on a small area.  I'll try and post some pix.  Thanks for the advice!
James
1970 22-2 FB
