Author Topic: 1999 Johnson Faststrike 150 fuel inj., should I ???  (Read 883 times)
May 06, 2008, 08:21:40 PM
Read 883 times
mopargreg
« on: May 06, 2008, 08:21:40 PM »
I have a chance to update my motor, right now I have a 1990 Johnson 150 carb motor with a 25" mid section, runs great(little cold natured), looks good/clean and pushes the boat pretty good.... I have a chance to pick up a 1999 Johnson Faststrike 150 fuel injected motor, 20" mid section with a bad lower unit, motor is also clean/looks good, runs good and great cyl. pressure across the board (hours unknown?).... My question is, are these motors reliable and what kind of gains should I expect going to a Fuel Injected motor? I have found a used lower unit for $600, and my buddy who has this motor just wants my motor in exchange even up, the only thing I would have out of pocket is the lower unit cost and a few x-tras for the swap, I would do the labor myself..... The transome on my boat has been raised about 5- 6" with the resto of the boat, can I go to a 20" mid section with a jackplate??  What do you guys think?????
Restored 1970 Aquasport 19-6 cc with 1990 150 Johnson
May 06, 2008, 08:29:00 PM
mopargreg
« Reply #1 on: May 06, 2008, 08:29:00 PM »
Here's a pic of the rear of the boat.....
July 31, 2008, 05:06:07 PM
fannydunker222
« Reply #2 on: July 31, 2008, 05:06:07 PM »
i havent herd to much about these motors but my buddy had a pair of them and the computers kept going out on them
steve k
July 31, 2008, 05:53:43 PM
Motor
« Reply #3 on: July 31, 2008, 05:53:43 PM »
IMHO - Don't use a 20" motor on that boat - it will be too low in the water and you want a jackplate to go up, not down.  But you might be able to swap mid and lower with your current motor and wind up with a 25.
