Gas tank Sending Unit
Topic: Gas tank Sending Unit (Read 592 times)
May 03, 2008, 01:48:35 PM
Read 592 times
SKR840
Guest
May 03, 2008, 01:48:35 PM »
I was wondering if any one knew weather or not you use any sealant when installing new gaskets on the sending unit or do you install them dry.
May 03, 2008, 02:41:10 PM
Mechanical Master
Gaskets
May 03, 2008, 02:41:10 PM »
Install them dry, but be careful tightening the screws. Tighten them snug first, then final tighten in a criss-cross pattern to ensure a good, even seal.
May 04, 2008, 10:14:22 AM
SKR840
Guest
May 04, 2008, 10:14:22 AM »
Thanks you, it appears that the previous owner of the boat cut up an inner tube to try and replace the seals, but that has rotted and is now leaking gas so its time to replace them the right way now.
May 04, 2008, 01:48:31 PM
Mechanical Master
And remember...
May 04, 2008, 01:48:31 PM »
Also remember to carefully clean the sealing/gasket surface. Get all the old residue out and make sure there are no pieces of "inner tube" or whatever on the surface.
Good luck!
